Going Green! Sort of... - Page 7
Go Back   Jeep Cherokee Forum > Cherokeetalk.com General Forums > General Discussion
Old 03-03-2017, 05:17 PM   #91
Maximus Absentius Modus!
well, spent most of the day fooling with the timing. still no love. A few adjustments in the timing have made things worse so tomorrow I will go the other way......
My build thread: Gemini
NP242 Hack n Tap (SYE) Install
May 2015 Modified Cherokee XJ of the Month
Old 03-04-2017, 04:53 PM   #92
Back in the GREEN!!!
Jetta is up an running, and quite well I might add!
After a few more Injection timing attempts, decided to crack the injector lines at the injector and bleed some more air out and whalaa she runs. New turbo can hit 25 PSI boost in a heartbeat. Gotta go easy on the skinny pedal! Feels soooo good to be driving her again.
Old 03-04-2017, 04:59 PM   #93
Congrats
230 hp 4.3L Chevy
Built 4L60E with manual lockout
Atlas 4 speed
Griffin radiator
On board air
Warn 9.5ti on custom bumper
7.5" RE front and bastard pack rear on custom long arms
31 gal. gas tank
Old 03-04-2017, 05:21 PM   #94
Sweet, good find....
Old 03-04-2017, 05:38 PM   #95
VaBeachMike
VaBeachMike's Avatar
Congrats! Glad shes up and running since the Ranger in the hospital
February 2017 Modified Cherokee of the Month
Living the Good Life!
Zephyr (Beach Crawler) 2000 Sport 4.0-Born 8-99-Adopted 9-2013
VaBeachMike is offline   Reply With Quote
Old 03-04-2017, 05:45 PM   #96
Lost in Thought
Attaboy gluck
February 2016 Modified Cherokee of the Month
March 2013 Stock Cherokee of the Month
2001 XJ: 4" lift (Rustys LCAs, MetalCloak UCAs, Tuff Country coils, IRO aal), 31x10.50r15 Cooper STT Pros, rear Spartan locker, SYE, custom gas tank skid, Durango steering box, Yakima roof rack on custom crossbars, WickedBilt LED lighting, 784 injectors, and Afe intake
Old 03-05-2017, 05:30 AM   #97
Thanks guys!!
Old 03-27-2017, 07:30 PM   #98
Another update!
Tweaked the actuator rod on the new VNT turbo, which basically determines how much boost the turbo will produce. VNT stands for "Variable Nozzle Turbine". Anything over 25 PSI and I stand a chance of killing another turbo. Even though it can produce 25+ PSI doesn't mean the bearings, which are just bronze bushings, can handle the revolutions. It just spins too fast for the oil to do any good, and overheats and the shaft breaks. Ask me how I know
Anywho, Adjusted the rod so I wouldn't go over 25 PSI. The car has been running great but I still wasn't comfortable pushing it.
I started to email back and forth with "Malone Tuning", who are the original producers of the tune in my car. I connected my Laptop to the car and made some 3rd gear runs to get some baseline readings. Gotta admit, this was fun, starting at 1500 rpm and under WOT clear up too redline (4500 rpm) and going about 80 mph. ZOOM ZOOM. Each run was to measure and save specific data. So once I was done with all the runs I had some data to send to Malone. After they got a chance to look at it, they said it was an "Old" tune and sent me a new and upgraded "stage 4" tune that maxes boost at 22 PSI. The tune was free but it cost me 60 bucks to rent the tool to flash my ECM. Plus a $125. deposit. After the tune was flashed, they car was more laggy but never boosted over 25. So I adjusted the actuator again and got rid of some of the lag. Boost stops and 25 and settles to 22 and stays there til redline. Car runs good now and pulls hard! I think I am good to go and shouldn't have to worry about pushing it too hard.
And now some eye candy!
Old 05-17-2017, 03:16 AM   #99
Just an update of the recent turn of events.
Took the Jetta on a road trip to Hershey PA, for a Union conference. She was running great up to this time, but oil pressure dropped to 20 psi an hour out of Hershey. Sweating this, I babied it there and back home, with no incidents. 450 miles round trip. Decided crank bearings were in order. Finished that up Monday night. Oil pressure is now 42 psi (2400 rpm at 70 mph ). I swear I work on this more than my Cherokee. Rough estimates put my mileage at 55 MPG .
Woot Freaking WOot
Old 05-17-2017, 06:25 AM   #100
I think you'd been better off sticking with the Cherokee. Gas savings couldn't be enough to cover all the work you put into it....
Old 05-17-2017, 07:08 AM   #101
VaBeachMike
Been lots of work put into the Jetta. Hopefully this will be the end if repairs for a while.
Sent from my iPhone using Tapatalk
Old 05-17-2017, 09:09 AM   #102
Lost in Thought
I'm with lizard. It ain't a cheap dd if you rebuild it constantly.
Old 05-17-2017, 01:09 PM   #103
I agree. But it was my fault for the engine rebuild. I think I have all that in check now. But don't let my woes scare you off. These are good cars with good reps. Wouldn't hesitate to buy another one.
