LinkBack | Thread Tools | Display Modes |
#16 | |
#17 |
What all did you end up trying? Did you replace your injectors... i been looking into it and im confused as all hell.
Orange top, 5.0 mustang injectors?? 2.4 neon injectors... blah IDK
1998 XJ Classic. 4.5 RC lift, some tires, some armor, more balls then brains. My jeep build: http://www.cherokeetalk.com/forum/f26/deepwater-jeep-7508/ |
#18 | |
coil pack plugs (now I run NGK plugs) injectors (ford mustang) I also wrapped the injectors with heat shield tape. The weird thing about it is it would misfire after long drives BUT it rarely ever throws a code now. It used to throw codes every time it misfired. |
#19 |
Did you ever replace your plug wires? even though they may look fine on the outside, they can still be jacked up inside.
SMITHTANGO CURRENT 96 XJ 4.0, NP231, 2" shackles/spacers, 31X10.50X15 Goodyear Wrangler Duratracs, Trimmed(cut and roll) RIP 97 ZJ 4.0, 4WD :( COTM Stock February 2010 WINNER |
#20 | |
#21 |
Nevermind, i give up
#22 | |
muddin moderator
requires a little bit of modding but have yall tried running a switch to yalls factory electric fan so you can turn it on with the vehicle stopped and there for keeping the the fuel from vaporizing
chris 1985 Dodge dually (6-8mpg dd and tow rig) 1998 jeep xj 1965 Chevy 1/2ton for sale or trade Quote:
#23 |
It's on my to-do list, im currently only running one fan.
#24 | |
muddin moderator
does yours not have the manual fan turned by the belt and the electric fan?
#25 |
I did have a clutch fan and an electric fan. But then i took off the clutch fan and replaced it with another elec. fan. Apparently the fan was not mounted as well as it needed to be and during some rough trail run... it was destroyed.
#26 | |
2001 XJ Sport "Patriot Blue" 5.5 RE lift, 33 BFG Mud's, Detours Backbone, MileMarker 8k winch |
#27 |
Mud, why the Ford Mustang fuel injector's? The 4l injector's are multiport and can be purchased at any pressure rate. What's the appeal?
#28 |
Stock 4.0 injectors are only single port.
#29 |
I can scan the box and order invoice I have to show you. The 1996 XJ 4.0L High-Output, should have a "raised plastic badge" on lower left side of rear lift gate that says 4.O Litre (on top) with High Output (below it). I have a full set of these injectors to install once it warms-up a little and once I locate an American made 2002 4.0L intake system. The injectors came from GB Remanufacturing, Inc in Long Beach, CA and weren't the least expensive of the injectors located out there. GB Part number is 812-11128 they are multi-port and metered to fire the same amount of fuel to each cylinder. Google GB Manufacturing. and take it from there. them, they have an active online tech line that can confirm. I called them to verify once I had them in my possession....a little late had they hadn't been multi-port. That's all I know. BTW...anyone out there know where I can find the 2002 intake that I am replacing my 1996 intake with??
#30 |
I had a friend that had a 92xj and he had similar issues, he replaced injectors and a few other parts and finally found the flywheel cracked it would be worth a look even if that wasn't the problem.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Misfiring and o2 sensors | spatacuulous | Cherokee Stock Technical Forum | 5 | 02-24-2010 10:20 AM |
| Bosch 36 lbs injectors (6) | CSaddict | For Sale | 2 | 02-23-2010 06:46 PM |
| Fuel Injectors not pulsing | BUCCaNOLES | Cherokee Stock Technical Forum | 2 | 04-27-2009 12:41 PM |
Previous Thread
Next Thread
