Jeep Cherokee Forum > Jeep Cherokee Forums > Cherokee Stock Technical Forum > Oil/Filter Combination?
Old 11-04-2008, 10:02 AM   #16
drakan1908
drakan1908's Avatar
Valvoline 10w30 and a Purolater or AC filter
drakan1908 is offline   Reply With Quote
Old 11-04-2008, 07:43 PM   #17
whowey
whowey's Avatar
Originally Posted by Kyle View Post
Interesting, I hear of a lot of people running into leaking problems when switching to syn after years of regular. Must be another internet myth.
Nope.. not a myth at all...
The higher detergent properties in synthetic oils clean out the deposits and crud left over from running dino oils. So if there was a leak that was clogged with those deposits you will get a leak as those deposits are cleaned out.
BTW.. I run cheapo farm store 20w-50 and a Purolator filter. My Jeep leaks oil WAY too badly to run my own oil in it.
whowey is offline   Reply With Quote
Old 11-04-2008, 08:08 PM   #18
JeepGodXJ
JeepGodXJ's Avatar
I run Castrol GTX High Mileage 10w-30 with a oversized WIX filter for better filtration.
I did however try Mobile 1 Fully Synthetic oil one time for about 1 day. But my oil pressure guage went off the scale (literatly). As in WAY to much pressure. I then changed back to coventional oil and have had no problems since.
Any of you guys ever hear of something like this?
BUMBLEBEE TUNA!
JeepGodXJ is offline   Reply With Quote
Old 11-04-2008, 08:40 PM   #19
Mobile 5000 and purolator filter.
Old 11-06-2008, 02:57 PM   #20
lornix
lornix's Avatar
Castrol GTX and Fram filter.
Every other filter I have tried leaks - every friggen one! I have heard bad things about Fram filters, but have never had any issues and have run them in all my vehicles for the past 30 years.
I change my oil about every 1000 miles or so as I spend a lot of time crawling at a low rpm with high engine temps, so the oil breaks down quickly.
I use Royal Purple in my diffs and tranny and regular ATF in the t-case. Diffs, tranny and t-case fluids get changed every spring.
89 XJ 5" lift, Truxs MTs, Winch, Lights ect.
Live life like a dog, if you can't eat it or hump it, piss on it and walk away :cool:
lornix is offline   Reply With Quote
Old 11-06-2008, 03:01 PM   #21
Kyle
The Guru of Nothing
Kyle's Avatar
Every 1000 miles? Why so frequent?
Free CT Sticker for 250 Posts - http://www.cherokeetalk.com/forum/f4/250-post-sticker-giveaway-3770/
Support CherokeeTalk.com! - http://www.cherokeetalk.com/forum/f4/cherokeetalk-supporting-memberships-1563/
TwoSpoke.com
"Its Not Just A Jeep, Its A Lifestyle"
Kyle is offline   Reply With Quote
Old 11-06-2008, 03:29 PM   #22
TrueBlueXJ
Squirrel Master
TrueBlueXJ's Avatar
"as I spend a lot of time crawling at a low rpm with high engine temps, so the oil breaks down quickly."
Low rpms = slower transfer of oil through the system, mixed with the high temperatures of off-roading due to the decreased air flow, causes the oil to burn up much faster than with regular driving.
2 doors, 4 squirrels, one nut
www.jeepinwv.com
TrueBlueXJ is offline   Reply With Quote
Old 11-06-2008, 03:32 PM   #23
nighthawkxj
nighthawkxj's Avatar
Cause he is running a fram filter. Actually needs changed that often.
run a fram for a full oil change, watch your oil pressure. Run a bosch (get the good one like i did) and run it the same way. Almost 10 lbs pressure boost instantly, and it stays the whole oil change.
Bosch Filter, Castrol Synth Blend.
been hearing good things about Royal purple though, any one besides seth run it on here?
Dalen -> Salina, KS
97 XJ Sport on 35s. Lifted, Locked, Geared, Custom Steel Work Bumper to Bumper. Built Not Bought!
Click here for Specs and Build
No God, No Peace. Know God, Know Peace
nighthawkxj is offline   Reply With Quote
Old 11-06-2008, 03:34 PM   #24
Kyle
The Guru of Nothing
Kyle's Avatar
I always run bosch, I didnt know Fram required that much attention though I knew they werent as desirable.
TwoSpoke.com
Old 11-06-2008, 03:35 PM   #25
I do this too (every 1000). I hardly get 2000 miles a year so i change it every 1000, or 6 months.
Old 11-06-2008, 03:37 PM   #26
Kyle
The Guru of Nothing
Kyle's Avatar
Well that makes sense, my rule of thumb is every 3000miles/6months.
TwoSpoke.com
Old 11-25-2008, 09:23 PM   #27
GardenGnome07
GardenGnome07's Avatar
For my last oil change I have a Fram oversized filter and Napa 10W-30. Haven't had any problems with the Fram.
1996 XJ Classic 4 door 5 speed
3" Rustys leaf packs with extended shackles
3" Rustys springs
Rough Country Adj. track bar
Custom front bumper
and a horn on the shifter!
PA Glocker #305
GardenGnome07 is offline   Reply With Quote
Old 11-26-2008, 12:42 AM   #28
Mobile 1 Synthetic, 5W-30 in the winter 10W-30 in the warmer months.
Wix Filter.
I switched to synthetic at 25,000 miles, when I first bought the XJ, so I noticed no oil leaks back then.
Old 11-26-2008, 06:13 AM   #29
xjjeepthing
xjjeepthing's Avatar
Motorcraft FL1a and Motorcraft Synthetic Blend 10w30 or 5w30
01 XJ /4+" lift /33" DC Muds /M/T Sidebiters/ Surco / Hi-lift /Pilot Navigator lights / Bad Apple Fab diff guards / Midland CB / Wilson antenna / Front and rear receiver hitches / Rusty's LCA's / Magnaflow cat back / Throttle body spacer / Jet Stage 1 / Pioneer & Fusion Sound / AJ's Super rails / Warn T case Skid / BW Flat Flares / Bed lined Rockers and Quarters / Big Daddy Tie Rod / Rusty's Steering Brace
xjjeepthing is offline   Reply With Quote
Old 11-26-2008, 06:23 AM   #30
bshack
Mobile 1 Synthetic with Mobile 1 filter every 7,500 miles. I bought it with 6,500 miles and went right to synthetic. I have a small leak at the front of my oil pan. It started about a year ago.
bshack is offline   Reply With Quote
Go Back   Jeep Cherokee Forum > Jeep Cherokee Forums > Cherokee Stock Technical Forum
Transmission filter?? finneys98xj Cherokee Stock Technical Forum 10 03-02-2010 10:59 PM
Replacing the Fuel Filter (Renix Era) XJ Stryker Technical Articles 8 12-02-2008 10:59 AM
Oil filter relocation kit GardenGnome07 Cherokee Stock Technical Forum 8 11-30-2008 06:48 PM
Oil Filter Relocation Jeepers Creepers Cherokee Modified Technical Forum 19 10-11-2008 01:37 PM
