Jeep Cherokee Forum > Jeep Cherokee Forums > Cherokee Stock Technical Forum > Oil/Filter Combination?
Old 03-08-2010, 08:59 PM   #46
OAS
OAS's Avatar
Mopar filter, and either Pennsoil Platinum 10w30 or RotellaT syn 5w40.
"Earth first", we can wheel on the other planets later.
OAS is offline   Reply With Quote
Old 03-09-2010, 04:19 AM   #47
danamos666
i just head on down to shcucks (o'reilly) and pick up there house brand 5w-30 in 5 quart jugs (usually get a cupl of singles as refills and backups) and the best fram filters they carry, i find it pretty easy to change my oil every 3k in my jeep, 5k in the ford ranger (its fairly new, low milage, and is a highway vehicle) and i replace the filters every other oil change, i just rinse them out in a small tub with a quart of 58cent oil, which to be honest is the only stuff i wont run in my vehicles, as 89 jeep said oil is oil, if its conventional they all run basically the same base stock with minor changes in the additives, i should know i got certified by valvoline a while back as an oil specialist
danamos666 is offline   Reply With Quote
Old 03-09-2010, 04:24 AM   #48
danamos666
wait, oas, why are you running such (fairly)high-end product? both of those oils are really only good for an xj between ~25k-<100k miles after that the house brand is actually better both for performace and fuel economy, and its less likely to wear your seals
Old 03-09-2010, 01:57 PM   #49
OAS
OAS's Avatar
PP or RTS "high end product"?
Not what i consider high end.
RoyalPurple, Redline, or Amsoil is what i consider high end.
PP and RTS are easily available at Wally's, not too terribly costly, and are good if you do extended drains.
Econo oils are o.k., but i want this ride to last.
Oil is cheap insurance in the long run.
Unless you enjoy rebuilding........
Old 03-09-2010, 06:58 PM   #50
millman
Originally Posted by TrueBlueXJ View Post
Valvoline 10w30 conventional, and a Fram Truck filter. The Jeep's a simple machine, so I keep it simple.
fram filter and rotella 10 w40 it's got zinc in it.
millman is offline   Reply With Quote
Old 03-13-2010, 01:58 AM   #51
cherokee9601
Mopar filter, Castrol Magnatech 10w40.
cherokee9601 is offline   Reply With Quote
Old 03-13-2010, 10:38 PM   #52
Flatdady
Flatdady's Avatar
10w40 castrol high mileage and fram tough gaurd filter-197,000 miles and going strong.
Flatdady is offline   Reply With Quote
Old 03-18-2010, 06:47 PM   #53
1999greencherokee
Rotella 10w-30 and Napa Gold
1999greencherokee is offline   Reply With Quote
Old 03-18-2010, 10:07 PM   #54
JpUseR96
Castrol 10w40, with an aditive "slick Fifty" every 40K miles
JpUseR96 is offline   Reply With Quote
Go Back   Jeep Cherokee Forum > Jeep Cherokee Forums > Cherokee Stock Technical Forum
Transmission filter?? finneys98xj Cherokee Stock Technical Forum 10 03-02-2010 10:59 PM
Replacing the Fuel Filter (Renix Era) XJ Stryker Technical Articles 8 12-02-2008 10:59 AM
Oil filter relocation kit GardenGnome07 Cherokee Stock Technical Forum 8 11-30-2008 06:48 PM
Oil Filter Relocation Jeepers Creepers Cherokee Modified Technical Forum 19 10-11-2008 01:37 PM
