Jeep Cherokee Forum > Jeep Cherokee Forums > Jeep Builds > 93 Cherokee Budget Build
Old 04-27-2009, 02:23 PM   #31
jakeWI
jakeWI's Avatar
Originally Posted by littleblackxj View Post
Look what just came today
ooooo you beat me to new shocks!!!! those are the ones i wanted. where did you get them from?
looking good
jakeWI is offline   Reply With Quote
Old 04-27-2009, 03:40 PM   #32
littleblackxj
Web Wheeler
littleblackxj's Avatar
looking good
Thanks Just a word of warning, they run a little short. They are for 4" of lift, and they only have about 1-2" of downward travel compared to when my jeep is level. I am going to run a 1" spacer in the front and BPE in the back to compensate.
1993 Cherokee - 33" Duratracs - Dana 30/44 - Rear detroit - 4.88- Rear Disks - RE 4.5"
littleblackxj is offline   Reply With Quote
Old 04-27-2009, 03:53 PM   #33
jerman75
jerman75's Avatar
is it a good idea to get shocks made for a couple inches of lift larger than the lift your actually running?
jerman75 is offline   Reply With Quote
Old 04-27-2009, 10:31 PM   #34
littleblackxj
Web Wheeler
Eh it can be. Depends on the shock really. What you want to do is buy shocks according to their compressed and stretched lengths so that way you have the best fit for your jeep.
Old 04-27-2009, 11:58 PM   #35
Kyle
The Guru of Nothing
Kyle's Avatar
Well matt glad they are working out for you, though I didnt have any doubts.
Free CT Sticker for 250 Posts - http://www.cherokeetalk.com/forum/f4/250-post-sticker-giveaway-3770/
Support CherokeeTalk.com! - http://www.cherokeetalk.com/forum/f4/cherokeetalk-supporting-memberships-1563/
TwoSpoke.com
"Its Not Just A Jeep, Its A Lifestyle"
Kyle is offline   Reply With Quote
Old 06-09-2009, 06:52 PM   #36
Overs88
hey what did you do to talk off your door and be able to put them back on
Overs88 is offline   Reply With Quote
Old 06-09-2009, 07:34 PM   #37
ZackXJ
Budget Master
ZackXJ's Avatar
ive been thinking about what i would do about the mirrors if i decided to put tube doors on that i could swap in or out with the stock door when i wanted, now i know, when i go on the road with the doors off... duck tape a mirror on! lol. nice rig man!
Rebel Flag - heratage not hate.
Proud owner of Bulletproof.
The Big Bad Jeep.
As soon as i get money coming back in the build will begin!
ZackXJ is offline   Reply With Quote
Old 06-10-2009, 01:23 AM   #38
Doobie
Doobie's Avatar
that's a sweet build you got going there. I really like your ingenuity
Doobie is offline   Reply With Quote
Old 06-12-2009, 01:15 PM   #39
littleblackxj
Web Wheeler
I started work on my rock sliders this week. I bought 20ft of 4x2 1/8" (didn't have 3/16") and 10' x 3" of 3/16".
I have everything made, i just need to drill 48 holes through 3/16", so it's taking me awhile. Once i'm done with that, I can mock it up and then weld the mounts to the sliders. I keep buying the entire dewalt drill set because the 1/2" drill bit is $16, while the entire set is $20 So right now I have 3 sets sitting at my house.
O and I did everything with an angle grinder, cut off wheel, and a 110v fluxcore lincoln electric welder.
Old 06-12-2009, 01:23 PM   #40
littleblackxj
Web Wheeler
O, before i get to involved with how I want to mount it, i'll ask you guys for advice. Right now I am planning on making brackets that go inside the frame and then bolt it all together. I've already cut the holes in my floor board so i'm not worried about that, i am just wondering how companies normally do it?
Old 06-12-2009, 08:40 PM   #41
Doobie
Doobie's Avatar
all you have to do is surf the web and see how they all do it.
If you look at AJs design, it seems to be one of the best, and most planned out.
Old 06-13-2009, 01:21 AM   #42
96sport
96sport's Avatar
The majority of companies will mount to the frame rail like you are and then they will also put another mount at the pinch seam underneath your door area.
Just Empty Every Pocket
96sport is offline   Reply With Quote
Old 06-13-2009, 01:26 AM   #43
littleblackxj
Web Wheeler
Do they thread holes in the frame or use a washer of somesort?
Old 06-13-2009, 07:44 PM   #44
littleblackxj
Web Wheeler
Does anyone know how to drill through 3/16" plate without killing yourself? I use cutting fluid and make a pilot hole, but when i go to drill using the 1/2" but, right before I am all the way through, it binds and sends me flying. It's a major PITA getting the last bit of the hole drilled. I have 36 more holes to drill so I need a solution.
I don't have a drill press so that isn't an option.
Old 06-14-2009, 11:49 PM   #45
Doobie
Doobie's Avatar
get a drill with a cord,(endless power) and go light, don't push real hard, just lightly let the bit just shave the metal off. it will take a long while, but hey, better than breaking bits and your arse.
Cherokee budget turbo build thread CSaddict Cherokee Modified Technical Forum 83 01-27-2012 07:15 PM
my mud toy build up muddeprived Jeep Builds 31 08-24-2011 12:52 AM
Budget Hole Patch and Rhino XJ Stryker Technical Articles 29 12-02-2008 09:56 AM
5.9 zj build ... _StationWagon_ Grand Cherokee Technical Forum 8 11-30-2008 11:58 AM
my 96 build up TripleXJ Jeep Builds 8 10-15-2008 12:57 PM
