Jeep Cherokee Forum > Jeep Cherokee Forums > Jeep Builds > Jonzer's XJ
Old 07-10-2010, 02:32 PM   #46
jonzer12
jonzer12's Avatar
Originally Posted by mcatald View Post
Looks like a bottle of Royal purple spilled on your lens.....
Man that looks like fun........I so want gears and a locker.
Couldn't find camera so its just a snapshot from camcorder.
The aussie was the best mod I have made to the heep by far.
2000 XJ 6" Lift, 35's MTR's, ford 8.8 rear, hp30 front w/ alloys. Lockers at both ends.
jonzer12 is offline   Reply With Quote
Old 07-10-2010, 02:36 PM   #47
mcatald
Is that from Randy's ring and Pinion? If you don't mind me asking how much was the aussie?
mcatald is offline   Reply With Quote
Old 07-10-2010, 02:42 PM   #48
jonzer12
jonzer12's Avatar
I bought and installed the aussie last winter, I got it from northridge4x4 for $230.
The gears/install kits/carrier are from Trent Fabrication. Best price by far of all the venders I pm'd on pirate4x4.com. CHEAP!
Randy's prices are nowhere near competitive to what you can get from vendors on pirate4x4.
Old 07-10-2010, 02:47 PM   #49
mcatald
Thanks for the info. How is the aussie when you turn? Is it manageable in the snow.
Old 07-10-2010, 02:52 PM   #50
jonzer12
jonzer12's Avatar
While I would never want an auto locker in the front in the rear its fine in winter.
I can donut the jeep at will but it is more than manageable. After a couple weeks I forgot its there as you adapt to it If anything it is worse on pavement as you can't feel the tire scrub during the winter.
Old 07-10-2010, 02:56 PM   #51
mcatald
Thanks for the info I now am sold on it and I will stop cluttering your thread.
Old 07-11-2010, 06:34 AM   #52
XJcoupe
XJcoupe's Avatar
Decided not to build the waggy 44, too expensive and my garage door height means I can't go over 35's so I am just going to build up a hp30 and ditch my lp30.
4.88's, master installs and a new carrier for the 30. I will run stock shafts and buy chromo's if they don't hold up. I drive like a granny anyways
nice choice of gears Justin
[QUOTE] I drive like a granny anyways
ya right buddy, not from this vid last week when I was out on the trail with you
- click on the pic - takes you to the video
94 XJcustomcoupe -chop, D60s front/rear, caddy motor snifin bbq juice, full rhyno paint, custom rust, 5 point seatbelts-so i dont havta listen to my wife say- "if you hit another rock, bump, tree Im gonna pee my pants" -haha
BUILD THREAD http://www.cherokeetalk.com/forum/f26/94-xjcoupe-slice-dice-3110/
Youtube Channel http://www.youtube.com/xjcustomcoupe
XJcoupe is offline   Reply With Quote
Old 10-21-2010, 09:54 AM   #53
jonzer12
jonzer12's Avatar
Well the new hp30 is slowly coming together. Its getting sandblasted right now and I have a local shop turning down some tube to sleeve the inside of the tubes with.
This guy showed up and I have some 30 spline chromolly axles on order.
Old 10-21-2010, 10:00 AM   #54
Deepwater Jeepin
Deepwater Jeepin's Avatar
Whats going on?... sounds beefy but i have never heard of that.
1998 XJ Classic. 4.5 RC lift, some tires, some armor, more balls then brains.
My jeep build: http://www.cherokeetalk.com/forum/f26/deepwater-jeep-7508/
Deepwater Jeepin is offline   Reply With Quote
Old 10-21-2010, 10:33 AM   #55
jonzer12
jonzer12's Avatar
Get some 2x1/4 tube and turn it down to ~1.950 Cut it to length and press it inside the axle tubes. Plug weld it and weld it at the knuckle. Still leaves you room to run a 1.31" 30 spline shaft but you have a dana 30 with 1/2 thick tubes.
No more bending, much harder to warp when welding on truss or brackets.
Old 10-21-2010, 11:56 AM   #56
XJcoupe
XJcoupe's Avatar
for a D30 it going to be BEEFY
Old 10-21-2010, 12:39 PM   #57
Deepwater Jeepin
Thats awsome, are you pressing it yourself? I would be interested in seeing some pictures if you can get them.
Old 10-21-2010, 01:04 PM   #58
jonzer12
jonzer12's Avatar
I will take pictures, I am getting the sleeves with an order of steel I am supposed to pick up next week. I am just gonig to knock them in with a sledge hammer. Just to be sure to leave enough room at the differential end to get a seal puller in there.
Old 10-21-2010, 05:46 PM   #59
CT99XJ
CT99XJ's Avatar
Interested in how the sleeving will turn out.
98 Grand Cherokee, "Projekt Plush"- 2" of up, 30" Coopers, leather, sunroof, 219k and counting
April 2010/May 2011 Cherokee of the Month
Originally Posted by Buffalo Phil View Post
Originally Posted by lifted1994xj View Post
CT99XJ is offline   Reply With Quote
Old 10-21-2010, 08:03 PM   #60
jonzer12
jonzer12's Avatar
It will work great. This is not new territory, you can buy kits to do this but I found it cheaper to have them made locally. This is also very common on JK front axles.
As I have invested a considerable sum in sticking with a dana 30 I want to take the time and beef up the housing properly.
