Jeep Cherokee Forum > Jeep Cherokee Forums > Jeep Builds > Just another LCG XJ on 35's...
Old 06-12-2009, 12:28 PM   #61
Chili Palmer
Chili Palmer's Avatar
I finally got some work done!
The other day I finally started finish welding my front bumper but I ran out of wire!
Yesterday I pulled the tank and cut the hole for some test fitting. Today I'm going to be picking up some 1" square stock to build a frame for it.
Here's factory...
Initial cut...
Just setting the tank in the hole...
That's better!
I plan on having the tank done tonight so I can start working on the rear bumper and cage tie ins so I can work on the cage tomorrow. Then I just need to get some misc. mechanical stuff finished up (bleed brakes, bleed clutch, front DS, etc.) before she's trail ready!
Chili Palmer is offline   Reply With Quote
Old 06-12-2009, 12:30 PM   #62
Kyle
The Guru of Nothing
Kyle's Avatar
Looks a lot better! Im really looking forward to pictures of the cage.
Free CT Sticker for 250 Posts - http://www.cherokeetalk.com/forum/f4/250-post-sticker-giveaway-3770/
Support CherokeeTalk.com! - http://www.cherokeetalk.com/forum/f4/cherokeetalk-supporting-memberships-1563/
TwoSpoke.com
"Its Not Just A Jeep, Its A Lifestyle"
Kyle is offline   Reply With Quote
Old 06-15-2009, 04:19 PM   #63
Chili Palmer
Thanks and I can't wait for the pics of my cage either! As it turns out I didn't get crap done to it this weekend...not sure when I'll get to work on it again but as previoulsy mentioned I really want this on the trail the week of the 4th!
Old 06-15-2009, 05:32 PM   #64
littleblackxj
Web Wheeler
littleblackxj's Avatar
Do you plan on boxing in the top of your tank so you can still put stuff in the back of your jeep?
It's looking really good btw. I'm definitely liking the fenders.
1993 Cherokee - 33" Duratracs - Dana 30/44 - Rear detroit - 4.88- Rear Disks - RE 4.5"
littleblackxj is offline   Reply With Quote
Old 06-15-2009, 06:09 PM   #65
Chili Palmer
Yep, will definitely have a storage tray of some type on top. And right now I'm thinking of laying the spare flat between it and the seats then have a cover of some type coming off the cage that's hinged. This way the spare will be out of the way until I need it and it would give me more storage? We'll see what happens...
And thanks for the props on the fenders...
Old 07-04-2009, 02:00 PM   #66
jakeWI
jakeWI's Avatar
nice job chili. just came across this. you must have updated while i was gone. nice job on the raised tank.
any more updates?
jakeWI is offline   Reply With Quote
Old 07-05-2009, 07:16 PM   #67
Chili Palmer
any more updates?
No updates really. I have the main hoop bent for the roll cage (been done for a while) and got the tank mounted up. Still need to finish the cage, fix the clutch, misc wiring and few other odds and ends. I'm on vacation this week but have family in town so I won't be able to work on it until the end of the week. I also need to order some more tube so the cage won't get done (if even touched) this week
Old 07-07-2009, 09:27 PM   #68
GardenGnome07
GardenGnome07's Avatar
Wow. Fantastic build.
1996 XJ Classic 4 door 5 speed
3" Rustys leaf packs with extended shackles
3" Rustys springs
Rough Country Adj. track bar
Custom front bumper
and a horn on the shifter!
PA Glocker #305
GardenGnome07 is offline   Reply With Quote
Old 07-08-2009, 12:22 AM   #69
CreepyKrawerOffroad
CreepyKrawerOffroad's Avatar
This is one hell of a build, great job on it. Looks like you got all the right fab gear for this. That is where I am lacking in my build.
June Modified Jeep of The Month
Mods to install:Dana 30 shafts, Ford 8.8, 4.88 gears, Locker (haven't decided what kind) Steering Box Brace, 35'' or 37'' Goodyear Wrangler MT or BFG KM2. What ever I can get the best deal at work.
CreepyKrawerOffroad is offline   Reply With Quote
Old 07-09-2009, 12:58 PM   #70
Chili Palmer
Thanks for the props. As far as the fab gear goes; that's where I started. All my buddies were spending money on lifts, lockers, etc. while I was buying tools. Now I'm trying to play catch up with the vehicle...
Old 07-28-2009, 01:08 PM   #71
matikos98
looks good... i love cherokee trucks they look amazing!
matikos98 is offline   Reply With Quote
Old 07-29-2009, 07:27 AM   #72
GardenGnome07
Anything new to update?
3" Rustys springs
Custom front bumper
PA Glocker #305
Old 07-29-2009, 10:41 AM   #73
Chili Palmer
Yes actually; over the weekend I finally got around to working on my front bumper! It's not done yet but almost. All I need to do now is decide if I'm going to fix the air leaks and use it as an air tank (which I probably will) then give it a paint of coat and call it good...
Here it is after the final grinding and before I welded it to the brackets...
Here you can see the holes I drilled to plug weld the top, front (2 spots) and bottom of the bumper to the bracket. It's also fully welded on the back side...
Some of the plug welds...
Sitting on the bench for final welding...
And that's where it's still sitting. I drilled a hole and tapped it for 1/4" NPT and hooked up the air compressor and found a few leaks so I need to fix those then I can paint and install it.
I also shortened up my front DS about 3" (No pics). This year XJ came with the GKN style DS so I bought a used one but it was too long because it was for the 4.0L/Auto and I have a V6/manual. I ended up using a 5.5" piece of 1.75" x .120 wall DOM as an interior sleeve which was plug welded and seam welded.
EDIT: Next is the rear crossmember/bumper then I'll finish up the cage and get some wiring wrapped up... And I still have to fix that damn clutch...
Old 07-30-2009, 07:44 AM   #74
GardenGnome07
Nice work man. Front bumper looks real clean. Can't wait to see that cage!
Good luck with the clutch. I recently replace mine and it sucked big time. taking it apart and putting the clutch and components in was a breeze. It was trying to put the tranny back in that was tough. You just have to muscle it in. Good luck.
3" Rustys springs
Custom front bumper
PA Glocker #305
Old 07-30-2009, 07:52 AM   #75
Carl
Carl's Avatar
Looking great man, I still need to get up that way to check out the rig! Maybe we can go wheeling after I get back from deployment.
Carl is offline   Reply With Quote
35's kmanxj5050 Cherokee Modified Technical Forum 17 02-02-2009 07:08 PM
35's with a 3 inch lift smokeater87 Cherokee Modified Technical Forum 10 12-02-2008 12:39 AM
35's???? kmanxj5050 Cherokee Modified Technical Forum 16 11-24-2008 10:27 AM
