Jeep Cherokee Forum > Jeep Cherokee Forums > Jeep Builds > My '92 four door Build
Old 07-22-2009, 12:51 PM   #16
BigBadXJ
BigBadXJ's Avatar
Originally Posted by Doobie View Post
how big of a lift did you end up with on the front?
Those stock 28's look so dinky!
I'm not sure yet but the coils are Rusty's 808's so they are supposed to be 6.5"-7" but for some reason it looks taller? Still got alot of work to do to get it even close to done but I hope i will be done soon. I have to get all the lift stuff done and the replace the brakes and front axle & DS u-joints. Then finish all the cutting on the body so I can get the body straight for paint.
BigBad Fab Shop 4x4 XJ Tube Doors
E-mail me for product info @ bigbadxj@gmail.com
BigBadXJ is offline   Reply With Quote
Old 07-23-2009, 09:42 PM   #17
BigBadXJ
BigBadXJ's Avatar
I measured today and it is right around 7" and the coils I got used so they should not sag. I mean they are very beefy.
Old 07-25-2009, 02:45 PM   #18
BigBadXJ
BigBadXJ's Avatar
OK I got the pass. rear together and a tire on for testing to see how much lift my 1/2 ton springs will give me and I was very surprised. It looks to have given me almost a full 6"-6.5"!!!! I was looking for 4.5"-5" so this is very surprising. I will have to take it all back apart to clean an paint them with some of that tractor paint, add the spring clamps and I need to add another stock main leaf to the pack cause the 1/2 ton leafs or a little short in the rear of the pack which will make it weak and maybe break. But I was very happy to see that my gamble worked out. I also have gotten the chance to see how much this jeep need maintenance, I will have to replace all the brakes and it looks like all the U-joints. Better I fix this stuff now before I put the 33"-35" tires on and every test drive have something go wrong you know.
Old 07-25-2009, 05:40 PM   #19
89xjgrey
89xjgrey's Avatar
The front bumper you are working on looks identical to the one I had and sold here in Ohio.
-Chrysler Certified Technician
Empire Offroad
"Remember mad cow disease? Well mad cow became mad person, which became mad zombie." -Columbus, Ohio Zombieland
89xjgrey is offline   Reply With Quote
Old 07-25-2009, 07:17 PM   #20
BigBadXJ
BigBadXJ's Avatar
Well I'm not working on yet. I was supposed to get it off a guy on offroadohio.com but it has not worked out yet. I hope to be able to get this week though. Then I well start working on it, Hell I may even use it as a base to build a few? Ya never know?When did you sell it and for how much?
Old 07-26-2009, 03:23 AM   #21
Doobie
Doobie's Avatar
it looks to be coming a long very nicely.
Doobie is offline   Reply With Quote
Old 09-05-2009, 11:18 PM   #22
BigBadXJ
BigBadXJ's Avatar
I'm waiting n money to com in to get the parts I need , so not much done but here is some engine pics I have been cleaning and going thru the engine.
Old 09-07-2009, 02:06 PM   #23
Doobie
Doobie's Avatar
nice intake!
Old 09-07-2009, 05:42 PM   #24
BigBadXJ
BigBadXJ's Avatar
nice intake!
It's just a Cheap cone filter and a piece of exhaust tube. It does the job though, and I do not care what people say it does help alot. Especially with my wide open exhaust.
Old 09-09-2009, 03:43 PM   #25
Doobie
Doobie's Avatar
it helps. I know it does. I have one just like it. I just wish there was a simple way to keep mud off it.
Old 09-10-2009, 09:20 PM   #26
BigBadXJ
BigBadXJ's Avatar
I was going to get one of those filter covers.
Old 09-14-2009, 10:14 PM   #27
Doobie
Doobie's Avatar
they dont work too well. unless you use an oil.
Old 09-27-2009, 01:10 PM   #28
BigBadXJ
BigBadXJ's Avatar
waiting on my black steelies to come in and I have tire changer....ssooo..I could not wait and wanted to see what my old SSR's looked with the leafs.
Old 09-27-2009, 01:18 PM   #29
BigBadXJ
BigBadXJ's Avatar
OK so now I know my leafs will work I took them back apart to clean, paint and get the shackles off( PAIN IN M ***!) even though I'm not going to need them for lift I want to put some betters ones on and I'm going to put on one of those shackle box's. I also pulled the axle out to clean, paint add gears and ZJ disc brakes and realized it needs a pinion seal and axle seals. So I may look for a 29 spline instead of building up a beat up 27 spline. I got pics I'll post asap. I also got a RC Track bar for $70 which puts my 7" lift cost up to $300!!! HAHAHA. But I still need the shackles and shackle boxs. Then I will do the front axle, hack-n-tap, bed coat the inside/ rocker panels and rubberized coating in the wheel wells and under carriage. Throw the 33's on and she how she runs.
Old 09-27-2009, 01:18 PM   #30
BigBadXJ
BigBadXJ's Avatar
Thanks, Here is a few pics I fiberglassed up a crack in the header panel and a pic of the emblem that I am putting back inside of the "JEEP" in the middle.
She needs some TLC but it should come around.
door removal wicked xj Cherokee Stock Technical Forum 14 01-01-2010 02:03 PM
6.5" door speakers xj98b Cherokee Modified Technical Forum 6 09-27-2009 11:17 AM
Door Latch issue Gearheadette General Cherokee Discussion 3 07-29-2009 12:29 PM
89 xj 2 door! Foul Ball Jeep Builds 17 07-20-2009 07:12 PM
having a problem with my door rangerfx4man Cherokee Stock Technical Forum 3 01-04-2009 10:42 PM
