My one year progress-BUILD - Page 29
Old 06-13-2016, 01:35 PM   #421
LeonFickett
LeonFickett's Avatar
Originally Posted by Gluckmysock View Post
Yep, been there, did that! on 31's and an open diff.
What U-joint? Nothing but Spicer for me!
It wasnt stock. It looks like I put a precision u joint in 2 years ago. I have a spare shaft I'm putting a moog in. I also found out my ball joints are completely shot after 230,000 miles lol. With the weight of the tire I always told myself the play was acceptable, with no weight on the knuckle it flops all over the place haha. Probably played a factor in the u joint holding up too...
LeonFickett is offline   Reply With Quote
Old 06-13-2016, 06:34 PM   #422
Maximus Absentius Modus!
I've killed precision in mine. Spicer takes a beating.
ZBeard: "How do you make good decisions? Good judgement. How do you get good judgement? Experience. How do you get experience? Bad decisions".
My build thread: Gemini
NP242 Hack n Tap (SYE) Install
May 2015 Modified Cherokee XJ of the Month
Old 06-13-2016, 07:35 PM   #423
craig69diesel
craig69diesel's Avatar
Ever seen the Almost Alloy shafts the Iron Rock Offroad sell? I kicked around getting a set.
craig69diesel is offline   Reply With Quote
Old 06-13-2016, 11:08 PM   #424
LeonFickett
I used a moog u joint in the new shaft and after removing the Spicer caps I found d they were all well greased still after 200k in the used shaft.. Oh well lol. The moog looks about identical. I by non-greasable u joints for my axle shafts and grease able joints for my drive line u joints.
I would love to pick up a set of chromoly shafts but the ears on the u-joint part of the shaft look just as small. Ive thought about custom building a 44 front but even then the U joints are the same size. Now that I've been doing more serious crawling and pushing my limits the weak points of the axle are definitely showing...
We'll I got the Ball joints, wheel bearings and U-joints/axle
done today. I've invested too much money into keeping this thing alive...
Old 06-14-2016, 07:27 AM   #425
craig69diesel
Those almost alloys have a tab the welds over the u joint cap to strengthen it.
Old 06-14-2016, 01:48 PM   #426
93_cherokee
93_cherokee's Avatar
Get axle shafts from abs. They use bigger u joints
93_cherokee is online now   Reply With Quote
Old 06-15-2016, 10:03 PM   #427
LeonFickett
Not on the newer style shafts. I think that only applies for 95 or 94 and below Cherokees.
Old 06-16-2016, 03:09 AM   #428
My 96 did not come with ABS, and when I blew out my axles and u-joints I replaced them with axles from a 98 GC with ABS. The ABS axles used the bigger u-joint.
Old 06-16-2016, 07:46 AM   #429
LeonFickett
Okay, apparently it is 1997+ that came with them. Factory non ABS 297 joints in the front axle shaft. Spicer has drop in replacement joints that are even beefier now. I think it's a 960 joint. Same size caps but the joint itself is larger and cold forged instead of hot forged like the 297.
My stock non abs shaft was a 297 and my replacement shaft happened to also be. Both 1997 Cherokee sports, non abs
Old 07-28-2016, 09:44 PM   #430
LeonFickett
Picked up some cheap dana 30 shafts from a 05 TJ. Replaced the U joints with Spicer 760 joints. Decided to give the "almost Alloy" weld on braces a shot. The failure point on these shafts tend to be at the U joint or the ears on the shaft, In either case you'll need new shafts even if the axle itself does not break. Replaced the inner axle seals while I was at it and noticed My backlash seems a bit excessive after some miles... Curious to see what will blow up next haha
I tried posting pictures but the phone app doesn't work anymore. . .
Old 07-29-2016, 07:44 PM   #431
I pretty much did the same swap on my 96 XJ. But my shafts were from a 98 WJ that had ABS. I agree, if your u-joint fails, your replacing axles anyhow.
Old 07-29-2016, 09:20 PM   #432
LeonFickett
Welded more than a needed too and didn't grind any welds off. Clearances checked out good so I left it. I figured when it breaks I'll have to replace it anyways.
Old 07-30-2016, 04:05 AM   #433
93_cherokee
Why did you weld it?
Old 07-30-2016, 01:37 PM   #434
LeonFickett
That's how the almost alloy caps work. It's just 1/8th plate steel bent to fit over the U joint caps. It strengthens the ears of the inner and outer shafts so they won't bend. I just welded more than I needed too because I don't plan on removing the caps or reusing these shafts again. Once they blow they're trash anyways.
Old 08-06-2016, 01:40 PM   #435
LeonFickett
Added some small light pods to my bumper to my bumper a month ago. Very bright for their size and make a world difference night wheeling. I didn't want to over do it with a full size light bar... 2 spot lights and 1 7in flood is plenty for me.
My '96 XJ... In progress. troygarris Jeep Picture Forum 2 08-09-2011 07:21 PM
My Dailey progress 1999 Xj sport Build jeeplover Jeep Builds 3 09-10-2010 05:36 PM
Progress 2slw4u Jeep Cherokee Modified Technical Forum 4 08-08-2009 01:02 AM
lift progress brooks_mcclintock Jeep Cherokee Modified Technical Forum 5 07-25-2009 05:39 AM
