Here is my half ass install/pic post.
RE long arm upgrade
Pro Comp track bar
Rugged Ridge SYE
04 TJ front drive line cut down
ES 9000 Pro Comp shocks with stem conversion
RE SS brake lines
Here is what I started with. JK UCAs cut down and re welded and Dodge UCAs for my lower CAs with 7.5 RE coils.
I took off the steering, control arms, and shocks and held the axle up with a tranny jack and a pole jack.
Some of the tools I used.
Then I cut the old CA mounts off with a sawzall, and used a grinder to try and smooth it out. (I cut my finger here pretty good here so I did not totally finish grinding it all off I will later)
I used another pole jack to hold the tranny and T case up and took off the old cross member, and then I mocked the RE skid and tranny mount up in place.
Then I placed the CA mounts up and marked them to drill all the holes. There are five on each pinch weld and five just on the inside of each uni frame.
Then snugged all the bolts.
Next I installed the CAs.
A couple more holes drilled in the uniframe.
All tightened up all of the bolts and tied up the loose ends and put it all back together. (damn there are a lot of holes to drill)
