Jeep Cherokee Forum > Jeep Cherokee Forums > Jeep Builds > My "Project Junk" Build
Old 02-13-2010, 12:08 AM   #31
JRW7072009
Originally Posted by 89eliminator View Post
nice. although your axle shock mounts are on wrong. the bolt should be perpendicular to the axle for proper performance.
Yes you are correct those were temperary from my old shocks, and I have bar pin eliminators coming in on monday.
JRW7072009 is offline   Reply With Quote
Old 02-13-2010, 12:15 AM   #32
JRW7072009
Originally Posted by jakeWI View Post
thats good to know. now that i have the JCR sliders first haha. post some pics when you get them so i know whats different
Lol.... I will post some pics for sure. I am curious to see what JCR does different for the RE LA kit vs there normal sliders.
Originally Posted by mcatald View Post
Pfft....whatever.
J/K Thats hella sick man. Really nice looking install. Man I wish I had a wagon load of extra cash kicking around to do something half as awesome.
Oh yeah, and a lift.
Well now... lol its just a bit from my tax return my wife was nice enough to let me do some stuff to make the XJ drive better. She said I got $2000 to do what I want and I spent about $1980.00 so I am pretty happy with what all I have got to do.
Old 02-13-2010, 02:42 PM   #33
JeeperMatt
JeeperMatt's Avatar
looks good. i can see that cross member having trouble with a lot of the rockrails that mount to the pinch welds?.
Not a real issue... I went with AJ's SuperRails for mine - emailed him prior to placing the order to let him know what's up (RE LA's and TnT's unibody stiffeners) and he modified the pinch-seam, relocated the holes so I could still get maximum attachment points, and shortened the mounting legs to compensate for the 3/16" the stiffeners widened the 'frame' rails. And it was all free
Little Miss 4.0 / AX15 / NP231, SYE, Woods 'shaft / 8.8 / RE 4.5 LA Hybrid, HD 3/8" LCA pockets / 33x12.50 MT/R Kevlar, Unique 15x8's / EBC Sport Rotors drilled, slotted, Greenstuff pads, ext. s/s lines f/r / AJ SuperRails / Treks unibody stiffeners / ZJ tierod, draglink / trimmed fenders, YJ flares / 136A alt. / Optima RedTop / 6-ga charging system wiring / K&N intake, TB spacer / Banks TorqueTube header > 2.25" > hi-flo cat > 2.5" straight pipe dumped / C4x4 'hooks / 2500w system
JeeperMatt is offline   Reply With Quote
Old 02-15-2010, 11:51 PM   #34
JRW7072009
Here are a few pics of before and after on the RTI ramp at work. All pics are just before my rear tire left the ground.
Edit: Before the LA upgrade...
After.....
Before....
After...
Old 02-16-2010, 06:55 AM   #35
Originally Posted by JRW7072009 View Post
Some shots of the kit installed.
The track bar installed.
I still need to get some longer brake lines before I test it on the ramp, they should be here next week.
(regarding the last picture) Do you have any binding with that trackbar? Usually the t-bars have a bend at the axle end to avoid hitting the upper part of the bracket when articulating. That t-bar on yours seem rather close to the bracket already without flexing. My gf's bro snapped his t-bar cuz his didn't have a bend at the axle. It happens mostly when the passenger side tire is stuffed and driver's side is at full droop.
oe kame ngenga
http://www.ironman4x4fab.com/index.html
Old 02-16-2010, 11:19 AM   #36
JRW7072009
I have trimmed a little bit of the bracket and when I do the steering I plan to cut more and reinforce it, but yes it does still hit on the bracket a little.
I want to build a different track bar, which is kinda why I just bought a Pro Comp one instead of spending more money on a nicer one. I would like to get it above the axle I am really waiting to do the steering and see how my angles look then build the track bar from there.
Old 02-16-2010, 04:51 PM   #37
myxj97
myxj97's Avatar
What type of rattle can paint did you use? It leaves a nice look to it and would be easy to touch up if you have to.
Fix em up, tear em up, start all over again
myxj97 is offline   Reply With Quote
Old 02-16-2010, 05:02 PM   #38
XJ Philly
XJ Philly's Avatar
I'm really digging this build, looks really nice
Wish I had a lift in my shop. . . .
XJ Philly is offline   Reply With Quote
Old 02-17-2010, 12:06 AM   #39
JRW7072009
I used Rustoleum Satin black, I have touched it up a few times already on the fenders and the hatch. I am happy with it.
Thanks, It makes things nice having a lift to use when I need. I dont get paid a ton of money but I get a few nice benefits from working where I work.
Old 02-17-2010, 01:18 PM   #40
89eliminator
89eliminator's Avatar
looks like that should work
89 MJ with some stuff
wi4x4.com
89eliminator is offline   Reply With Quote
Old 02-23-2010, 11:31 PM   #41
JRW7072009
Well my JCR sliders showed up, they dont look like they are made to work with my RE LA kit I hope I am wrong but I put one up to both sides of the Jeep and they hit right where the skid bolts up to the pinch weld.
I paid 5 dollars extra so they will build them to work with the RE LA kit. Should of went with the AJ sliders.
Old 02-23-2010, 11:43 PM   #42
jakeWI
jakeWI's Avatar
contact JCR and see what they say. maybe they will work something out with you
jakeWI is offline   Reply With Quote
Old 02-24-2010, 12:27 AM   #43
JRW7072009
I just sent them a email and I will call them tomorrow for sure. I hope they will help me out or I guess they better help me out... lol. I have the receipt showing the order with the $5 charge to make them work with my kit.
Old 02-25-2010, 11:46 PM   #44
JRW7072009
Small update, I installed some Bar Pin eliminators and my steering showed up in the mail. I hope to install them along with my sliders within the next few days.
Here is what came in the mail today I got the reamer from Snap-On.
Here are my sliders, I need to cut off the "arms" from the rail and move them down about 3" to clear the RE skid plate this what JCR told me to do.
I will get posts up pics when I get done installing the steering and sliders.
Old 02-26-2010, 10:53 AM   #45
riderxmjk
riderxmjk's Avatar
sick build
94xj
90 6st 4.0l
chrome air intake
3in rough country lift
31 truxs ats
procomp 51s
unidin cb
2 102in whip
stickers
subs 2 12s* update 16in kicker sub in vented box
spx 1000w amp
pioneer speakers
jvc25 deck
chains straps
riderxmjk is offline   Reply With Quote
Cherokee Forum's 1st Annual Four Corners Trip "Asian Express" cosxjfan Trail Pictures & Discussion 15 05-20-2011 10:10 PM
North Eastern Oregon 4Wheeling "meet and greet" warrpath4x4 North West 0 12-19-2009 09:07 PM
The "Black Hole Project" poorboy_616 Cherokee Modified Technical Forum 2 10-02-2009 12:27 AM
((HELP))) 97 Jeep Cherokee "Power steering pump problem" Boshzilla Cherokee Stock Technical Forum 1 08-09-2009 10:21 AM
Project "Silver Dollar" nick_n_ii Jeep Builds 19 04-02-2009 05:05 PM
