07-28-2010, 11:56 PM
#106
Originally Posted by CT99XJ
i like the hood vents, dude. rims are nice, and out where you are you shouldn't need an agressive tire anyway- a lot of the dry stuff is perfectly fine with an a/t.
Thanks, the hood vents are working pretty well.
Yes this is true we dont get any snow only rain in the winter.
07-29-2010, 12:37 AM
#107
How does your temp sit with the vents?
98 Grand Cherokee, "Projekt Plush"- 2" of up, 30" Coopers, leather, sunroof, 219k and counting April 2010/May 2011 Cherokee of the Month
Originally Posted by Buffalo Phil
Originally Posted by lifted1994xj
07-29-2010, 09:12 PM
#108
Well it does not get as hot as fast and it cools down a lot faster. It still climbs to about 220-230ish while not moving but almost as soon as I start moving the temp goes down quick.
07-29-2010, 09:14 PM
#109
Here is with the new wheels, not a whole lot different then the steelies but much smoother and quieter.
There 35/12.50/15s on 15x8 wheels with 3.75" of BS
07-29-2010, 09:21 PM
#110
MMMMMMmmm..........Very nice dude.
07-29-2010, 10:09 PM
#111
looks real good!
07-29-2010, 10:26 PM
#112
Thanks guys.
07-30-2010, 08:16 AM
#113
very nice
Quick hold my beer , this will be good
07-30-2010, 01:49 PM
#114
Looks great! I want 35s now lol
2000 XJ w/ 4.5" Rusty's, 31" Mickey Thompson Baja Claws, 15x8 Pro Comp D Windows, PowerTrax No-Slip, JKS discos, CB, 4ft Firestik
09-02-2010, 10:59 PM
#115
dude i love the paint job..i read you used 400-600 to grind the paint...can you post the steps you used?..
thanks...
awesome jeep btw
2001 xj 4.0 aw4 Daily driver and tow rig
1991 yj 60/14 iroks (40s) 302/np435/np205 103 wb(still a work on progress)
09-06-2010, 09:19 PM
#116
thanks...
awesome jeep btw
Thanks, well just checked cause its been a while I used 220 grit to start then went to a 400 wet or dry sandpaper.
I used a electric sander with the 220 then did the rest by hand with the 400 till it was nice and smooth. I used my hose and a bucket of water to wet it down.
My clear coat was flaking off pretty bad, that is why I used the 220 grit, so really just took all the clear off for the most part..
Here on the drivers side is after the 400 grit and the passenger is with the 220.
11-09-2010, 10:41 AM
#118
Well I went with some different D rings to save a little cash. Here is a bad cell phone picture I will get better ones today.
I reinforced the cross member with some 3/16" steel plate I will take it down the sides of the frame rails. I also will be adding a receiver to the front.
Its far from done I still need to reinforce the frame and cut some of the cross member out but here it is so far.
11-09-2010, 12:25 PM
#119
Great build.
If you have to worry about your paint stay on the road.
11-09-2010, 04:53 PM
#120
Looks good! What size steel is that going across, 2x3?
