XJSuperman's 2001 XJ - Page 32
Old 01-09-2016, 10:17 PM   #466
Its cleaned up quite a bit, but I need to finish that, and cut one more spot out. Then starts the new metal additions. A couple little pieces, then some big ones. Lots of seam sealer and paint involved.
February 2016 Modified Cherokee of the Month
March 2013 Stock Cherokee of the Month
2001 XJ: 4" lift (Rustys LCAs, MetalCloak UCAs, Tuff Country coils, IRO aal), 31x10.50r15 Cooper STT Pros, front locker, SYE, custom gas tank skid, Durango steering box, Yakima roof rack on custom crossbars, WickedBilt LED lighting, 784 injectors, and Afe intake
XJSuperman is online now   Reply With Quote
Old 01-10-2016, 01:06 AM   #467
JeepFreek
Where am I???????????????
JeepFreek's Avatar
Makes me scared about mine. 5+ years of MI weather.
You're not stuck if you're still moving.
2013 June Stock COTM
2014 October Stock COTM
JeepFreek is offline   Reply With Quote
Old 01-10-2016, 05:45 AM   #468
Maximus Absentius Modus!
Really gives you an idea of how thin the metal is to begin with.
Any wonder why we need frame stiffners?
ZBeard: "How do you make good decisions? Good judgement. How do you get good judgement? Experience. How do you get experience? Bad decisions".
My build thread: Gemini
NP242 Hack n Tap (SYE) Install
May 2015 Modified Cherokee XJ of the Month
Gluckmysock is online now   Reply With Quote
Old 01-10-2016, 11:05 AM   #469
Default Frame? What Frame?
After cutting the frame and floor out of the camper project, frame stiffeners have moved up on my priority list. The frame rail itself really is not that thick either. I think the stiffeners I want are twice the thickness of the actual stock frame rail.
http://www.hooliganoffroad.com/colle...mid-stiffeners
JandDGreens is offline   Reply With Quote
Old 01-14-2016, 07:12 PM   #470
Still chipping away at my floorboard project....been at the shop all day and sorta getting somewhere. Almost all of the smaller holes are patched and primed, leaving the large area in front of the seat-bracket-truss-mount to be done yet.
Old 01-14-2016, 10:03 PM   #471
Floor boards are looking good. Nice!
Old 01-14-2016, 10:05 PM   #472
Veddy Nice!
Old 01-14-2016, 10:18 PM   #473
Those are just the smaller holes behind the seat bracket mount. The whole front section from pedals back to the seat mount still has to be done. Its all cut out, and sorta cleaned up, but it needs primed, painted, and a new piece fitted, cut, welded, and primed, painted, YOU GET THE IDEA.....
Thanks for the compliments guys.
Old 01-14-2016, 10:25 PM   #474
Don't try to paint it prior to welding, the paint will contaminate the weld. But you can buy weld through primer. it's pricey. The rear patches look good. but make sure and use seam sealer, so you don't get water and moisture up into your new panels.
Old 01-14-2016, 10:31 PM   #475
Yeah, Ive got weld-through primer. Cost me 16 bucks for the can, and retails at 28 or something crazy....
I mean painting inside the unibody rails, and places not being welded, but impossible to paint after welding is done.
Pic: that little square to the left of the larger patch is now welded in, and Im finishing the underside of it tomorrow.
Old 01-14-2016, 10:37 PM   #476
Oh, Ive got seam sealer too, but thats later, after all the welding is done. And I can't remember with which type I bought, but primer and paint go either before or after the sealer. I read like 6 different directions when I was buying it.
Old 01-15-2016, 06:18 AM   #477
Looks great Superman ,most of the available seam sealer sold at advance or autozone is paintable. The directions should say.
Old 01-15-2016, 06:22 AM   #478
FWIW, I prime, seam sealer, then paint. It depends on your brand of seam sealer, I don't know if you can paint on all of them.
Old 01-15-2016, 06:23 AM   #479
Why has no one commented on that great big elephant in the room??
Old 01-15-2016, 06:51 AM   #480
Mmmm,missed that.
