Jeep Cherokee Forum > Jeep Cherokee Forums > General Vehicle Forum > Engine Life?
Old 07-05-2010, 08:38 PM   #16
RenegadeStang
RenegadeStang's Avatar
Originally Posted by danamos666 View Post
252k, and running great, but my exhaust is getting bad, the o-ring is the easiest problem to prevent, its mostly caused by cheap oil changes where the technician didnt prime the o-ring with oil before installing the filter
This o-ring is the one between the block and the oil filter adapter. Not the o-ring that comes on the filter.
RenegadeStang is offline   Reply With Quote
Old 07-05-2010, 10:14 PM   #17
jeepgod
Banned
Default o ring
That is good to point out.....I should have clarified a little more lol.
jeepgod is offline   Reply With Quote
Old 07-06-2010, 12:17 AM   #18
Moore825
Moore825's Avatar
When I worked at a shop, a guy came in for an oil change on his XJ that had 317k miles on it. Used it for trips to Colorado and New Mexico trails. He mentioned he was looking into rebuilding it for the first time.
Like they say if you take care of it, it will take care of you.
2000 XJ w/ 4.5" Rusty's, 31" Mickey Thompson Baja Claws, 15x8 Pro Comp D Windows, PowerTrax No-Slip, JKS discos, CB, 4ft Firestik
Moore825 is offline   Reply With Quote
Old 07-10-2010, 08:57 AM   #19
wicked xj
wicked xj's Avatar
270xxx still runin strong and a bought it with 256xxx i put mostly trail time on it
99 blazer
03 ranger
86 t/a
''if you've got nuts follow my ruts''
r.i.p. 93 xj(aka tigger) you will be missed
wicked xj is offline   Reply With Quote
Old 07-10-2010, 11:44 AM   #20
superstratjunky
superstratjunky's Avatar
Mine I was told was a swap with 80,000 & the OD says 165. Had to change the thermostat, replace missing bell housing bolts, & lengthen the kick down cable for the tranny.
Jimbo
Dirt & Rocks rule
"We the people are the rightful masters of Congress & the courts, not to overthrow the constitution, But to overthrow men who pervert the Constitution." Abraham Lincoln
superstratjunky is offline   Reply With Quote
Old 07-20-2010, 02:20 AM   #21
JRW7072009
i assume you re-geared??
Yes 4.88s
JRW7072009 is offline   Reply With Quote
Old 11-17-2010, 01:31 PM   #22
JeepersCreepers
JeepersCreepers's Avatar
My 1993 Grand Cherokee Laredo has 185 and change.
I had that ticking sound for about 8,000 miles, then i found out what it was. The lifter for the cylinder number 1 exhaust valve dropped. After it happened i had to drive it 9 miles to my place. When all was said and done, a good 1/4" to 1/2" was shaved off compared to the other lifters. Enough to allow the spring to be pulled out with no effort from the top. Replaced the 12 lifters and the head gasket. Ever since my oil pressure has been all wonky. I was worried about the extra clearance between the camshaft and the bearing so i upgraded to 20W-50 oil with the K&N oil filter. Its been about 7,000 miles now and she still runs like a champ.
You think its funny to make jokes about me? Do you think you look cool by telling me off, and saying how better you are? This is my life, and how i drive, and how I form my sentences is up to me. At least I don't drive my moms station wagon. You have no idea how high I can fly.
2-01-09
Amy-Roxy =]
JeepersCreepers is offline   Reply With Quote
Go Back   Jeep Cherokee Forum > Jeep Cherokee Forums > General Vehicle Forum
How much life in a Grand Cherokee? Greenmachine Grand Cherokee Technical Forum 27 08-26-2011 02:38 PM
Life span of a timing chain. Ogre Cherokee Stock Technical Forum 8 06-02-2010 09:53 AM
promoting a looong engine life Red99XJsummitCO Cherokee Stock Technical Forum 8 04-12-2009 11:36 AM
doing clutch on 2.5l with x4 and " make my life easier" tips? 86rokee Cherokee Stock Technical Forum 21 02-18-2009 11:41 PM
the 6 truths of life XJ Stryker General Discussion 9 11-18-2008 09:36 PM
