Jeep Cherokee Forum > General Technical Forum > Technical Articles > Power inverter/Outlet install
Old 02-04-2009, 09:08 PM   #31
Ritter4.0
Ritter4.0's Avatar
Originally Posted by Jeonlyep
I made coffee, ran drills, a grinder and a weed eater with my 800/1600....
But it quit for some reason, I have a smaller one in there now, to power the laptop.....
Mounted mine to the passenger side of the transmission hum
p.
This is the reason I mounted my amp in my headliner, and will do so with an inverter if I get one. If it gets wet in dirty water its gone. If it shorts and drys out it could burn your jeep. Its not too difficult and can save your amp/inverter and your jeep.
Ritter4.0 is offline   Reply With Quote
Old 02-04-2009, 09:41 PM   #32
tupton
tupton's Avatar
After seeing that headliner, I've seen everything!
Tom Upton
To err is human, to own a Cherokee is devine!
tupton is offline   Reply With Quote
Old 03-04-2009, 08:37 PM   #33
GardenGnome07
GardenGnome07's Avatar
Originally Posted by Ritter4.0 View Post
1996 XJ Classic 4 door 5 speed
3" Rustys leaf packs with extended shackles
3" Rustys springs
Rough Country Adj. track bar
Custom front bumper
and a horn on the shifter!
PA Glocker #305
GardenGnome07 is offline   Reply With Quote
Old 05-24-2009, 09:17 PM   #34
mud-dog27
mud-dog27's Avatar
id be scared of that headliner catchin fire....it does however top the shag liner in the VW that my buddy just bought for a DD
as for the inverter ive got a 300watt mounted on the passenger side kick panel i couldnt see myself needing any bigger as i bought it mostly for charging my phone(i dont have a car charger and my sirius takes the 12v outlet) charging my camera and on occasion a drill or grinder which it ran fine when i tried but like someone else said try running something like a light from the other socket to stop any problems
i also got it for i think $100CDN at canadian tire on sale it was more of an impulse buy then anything but its been good when camping for when the camera goes dead or on road trips
pretty much its not a neccesity but more of a luxury
mud-dog27 is offline   Reply With Quote
Old 05-27-2009, 04:00 PM   #35
jerman75
jerman75's Avatar
be careful mounting electrical items that generate heat upside down. when they are designed the heat disipation is not set up for inverted mounting in most cases. the heat rises right to the circuit boards instead of the heat sinks being able to pull the heat away from the boards
jerman75 is offline   Reply With Quote
Old 01-04-2010, 03:41 PM   #36
Braindead
Braindead's Avatar
You know I was looking at this tread and I guess I'm a techie geek but I plan on running about a 1k with 3 batts to power a small dual core system and a 15" monitor up front. My big thing is the battery set up on my Xj. I plan on relocating all of them under the back seat and putting them inline for a larger cell. Anyone have any good ideas on this? Or advice?
Braindead is offline   Reply With Quote
Old 01-04-2010, 04:38 PM   #37
I use mine for a small refrigerator.
Old 01-04-2010, 05:39 PM   #38
Prerunner1982
Prerunner1982's Avatar
There is not enough room under the back seat for 1 automotive battery muchless 3 unless you plan on hacking the floorboards. What type of batts are you planning on using?
Jon
1993 2 Dr Sport 4x4
Prerunner1982 is offline   Reply With Quote
Old 01-04-2010, 05:45 PM   #39
tbone
tbone's Avatar
p.
Dude your jeep needs a hair cut.
I've got a 350 watt I need to get installed.
Who needs pavement, I own a XJ.
tbone is offline   Reply With Quote
Old 01-04-2010, 05:46 PM   #40
Braindead
Braindead's Avatar
Well the hacking is not beyond my demented mind? And I want to use red tops but will not be getting them all at once. The price on them hurts.
Old 01-05-2010, 12:17 AM   #41
smithtango171
smithtango171's Avatar
3 red tops??? that'll put a dent in the wallet lol
smithtango171 is offline   Reply With Quote
Old 01-05-2010, 12:22 AM   #42
I run dual Optima batteries with the inverter mounted on top behind the seat.
Old 01-05-2010, 12:25 AM   #43
smithtango171
I want to get a detours tailbone system and then run a custom box arrangement for the cargo area with a spot for dual red top optimas.
Old 01-05-2010, 12:26 AM   #44
Braindead
Braindead's Avatar
I plan on being able to sit and play the computer with the engine running or not. And may eventually use it for Computer trouble shooting. so I want the power to spare.
Old 01-05-2010, 12:40 AM   #45
You will need to isolate one battery for starting and work off two. If you pull your starting battery down too far, it will have insufficient voltage to operate the ECM.
Go Back   Jeep Cherokee Forum > General Technical Forum > Technical Articles
Shackle Install muddeprived Technical Articles 30 05-24-2011 07:13 PM
How to Install a Lift on a XJ Kyle Technical Articles 15 08-28-2009 10:09 AM
SYE Install with pics 87xjco Technical Articles 11 07-25-2009 07:27 PM
4x4 Hi,and power Red99XJsummitCO Cherokee Modified Technical Forum 18 01-05-2009 05:01 PM
Coal power. jonb8 General Discussion 16 11-03-2008 05:47 PM
