10-19-2009, 06:54 AM
Nice snag on the rims! You can always replace the tires with a matching set at some point.
01-22-2010, 11:44 AM
update long overdue...
im cutting them this weekend, along with putting my white face dash cluster in, rewiring my CB, and fixing my dome light switch on my door. randomly itll start flickering and it drives me ape****. thinking about doorless in the summer so possibly just eliminating them altogether, and using the headlight switch to turn on the interior lights
98 Grand Cherokee, "Projekt Plush"- 2" of up, 30" Coopers, leather, sunroof, 219k and counting April 2010/May 2011 Cherokee of the Month
Originally Posted by Buffalo Phil
Originally Posted by lifted1994xj
01-22-2010, 10:57 PM
Lighting Guru
did u ever change ur tires
I got a Jeep for a reason, to pull ur dumb ass out.
Originally Posted by Lyon
Like a good neighbor State Farm is there.........With Rob the lighting Guru.
08-05-2010, 11:47 AM
1998 xj with 3 inch lift with 31 by 10.5
i have 98 xj cherokee with a 3 inch lift with 31 by 10.5 tires on it now almost bald i got a set of 33 by 12.5 i wana throw on i just wana no how much cutting im gona hafta do and if they rub wen u cut the wheel all the way and how does it do in the woods and should i take off rear sway bar?
08-05-2010, 05:23 PM
are the 33s 12.5 wide ?
08-05-2010, 06:57 PM
You can ditch the rear sway bar if you feel comfortable driving without it. It's personal preference but it's not REALLY needed.
08-05-2010, 07:33 PM
#22
98 cherokee 3 inch lift
so i can leave the sway bar but wat about the 33s bein 12.5 wide cause every forum i saw that said u can doit with a 3inch lift didnt say a width of the tire so b4 i go cuttin i wana make sure it can be dun with 33s by 12.5 wide with a 3 inch lift?
08-05-2010, 09:20 PM
#23
Have you decided on a wheel yet? The backspacing of the wheel plays a big role on whether you can fit it or not.
08-06-2010, 02:26 PM
#24
ya
ya i have 33 by 12.5 for 15 inch rims already wats back spacing
08-07-2010, 06:23 PM
#25
back spacing is the distance between back of the wheel and the mounting pad(where the bolt holes are). With 33x12.5 tires on stock wheels scrubs my leaf springs and the coil springs on the right side. If you want to keep stock wheels you can buy wheel spacers.
08-07-2010, 08:41 PM
#26
o i got u well these are 8.5 wide after market pro comp 15 inchs idk if that makes a diff i wanted 2 do 2 inches on each side anyway and i gues with the 3 inch lift it cauldnt hurt anyway
08-10-2010, 10:26 PM
#27
The backspacing is the distance from the back side of the contact patch of the wheel to the inner rim. The most common for aftermarket wheels range from 3.5" to 4.5". with a 33x12.50 tire, you'll at LEAST want something less than or equal to 4" otherwise you'll be rubbing on your leaf springs and control arms.
I ended up with a rather large cut in the front, but I don't rub even at full stuff.
08-11-2010, 02:57 AM
#28
Hey guys, sorry I'm late to the party here, also I realise there has already been some slicing done but for future refrencing for anyone who may search this. IT CAN BE DONE!!! If you don't mind your fender flares being wacked off from time to time...
We recently lifted my buddies 99 Sport 3.5" and he didn't have any to put on so I let him use my old Comanches tires. With no trimming what so ever we fit 33x12.5 on rims with 3.75 backspacing under there. I will admit there is no flex at all and the fender flares will be knocked off on harsh roads or bumpy trails.
08-11-2010, 06:58 PM
#29
ya i got llike 5 inches im gona have to get spacers plus i mesured frm the 31s by 10.5 that are on there now to the leaf and i got less then 2.5 inches so im gona need spaces i found a whole set of 2 inch spacers for 160 shpped
08-11-2010, 07:03 PM
#30
and what about rasing the back of the hood to run cooler is that a good idea and does it make that big of a dif and if so how high should i go and does it affect the hood closing?
