Jeep Cherokee Forum > Jeep Cherokee Forums > Grand Cherokee Technical Forum > e3 spark plugs..
Old 02-20-2010, 11:10 PM   #16
98xj_John
98xj_John's Avatar
maybe be crazy but has anyone ried the pulstar plugs? They have been dyno proven.
98 limited... mutt mix lift Clayton 5.5 TJ coils Rustys 4.5" leaf pack with Clayton 6.5" AAL Iromman upper an lower adj control arms RE sf track bar 33" claws 4.0l 242 d30/8.25 27 spline wrapped header custom intake bored TB 3"flowmaster custom front bumper detours slider h4 conversion w/6000k hid leather tints an sticker More to come.
Lift It... Fat Chicks Can't Jump
98xj_John is offline   Reply With Quote
Old 02-20-2010, 11:49 PM   #17
88fadedglory
I did a search on Google just now ... and came up with about two dozen scam alerts on these plugs.
Folks,
A long time ago, one of my favorite early Sci Fi authors, Robert Heinlein, came up with an acronym: "TANSTAAFL" There Ain't No Such Thing As A Free Lunch. (I quit reading him when he got too political and began advocating incest)
When I read "dyno proven" I get suspicious real fast, thanks to dyno claims on such things as K$N airfilters (one test, Car Craft Magazine, claimed some 12 Hp for a K$N drop in filter but failed to mention the cat back exhaust, the headers and a reprogrammed F.I. compuuter) and spark plugs, among others.
88fadedglory is offline   Reply With Quote
Old 02-20-2010, 11:57 PM   #18
98xj_John
98xj_John's Avatar
ya forgot to add quotes around dybo proven.
I saw a while back they used them on horsepower on spike an did a before and after on a vette an "added" somthing like 26hp an 29ftlbs.
I don't believe they are a screw in 20HP average
But hell at 25$ each they better do some damn good.
Old 02-20-2010, 11:57 PM   #19
98xj_John
98xj_John's Avatar
Old 03-04-2010, 08:46 AM   #20
BACKWOOD
BACKWOOD's Avatar
I run those Bosch platinum +4, not three FOUR lol. And their not a big deal. I guess you couldn't go wrong because they are pre gaped. Their not bad but i didnt notice a major improvement
TRAIL RIG:
89 Cherokee - 8.5" & 35's.
Front Aussie Locker and Chromoly shafts.
ARB front bumper & JCR rear.
Advanced Adapters SYE.
JCR 1 Ton OTK steering and T&T Customs Trac bar.
Project Goldielox
http://www.cherokeetalk.com/forum/f26/build-goldielox-8054/
BACKWOOD is offline   Reply With Quote
Old 03-04-2010, 10:05 AM   #21
89xj4.7
89xj4.7's Avatar
i put the E3 plugs in my jeep saturday. other than it idles smother i dont notice much.. when i put them in my mustang i noticed alot..... then again i still cant find the problem with my jeep and its hard starting issue.... maybe this has something to do with my mph being bad and it pinging out the arse on 87.
89 4 door. 4.7 stroker/auto. ruff country 4.5 lift. dana 30/ford 8.8 285-75-16's
89xj4.7 is offline   Reply With Quote
Old 03-04-2010, 10:06 AM   #22
When was the last time you changed your O2 sensor?
Old 03-04-2010, 10:18 AM   #23
89xj4.7
89xj4.7's Avatar
thank you... i havnt. and something else i noticed, i dont have my knock sensor hooked up... well, its not even in the block. gonna go put that in and change O2...... does the 89 set the CEL when something goes bad? i have no light coming on if so.
Old 03-04-2010, 10:25 AM   #24
O2 sensors can wear out and cause the mixture to be rich which will give you bad milage without a CEL. It will only go on if the sensor fails entirely. If the knock sensor is hooked up, but not in the engine then the light would not come on either. Also that knocking would rob you of some milage too. Better get them hooked up.
Old 03-04-2010, 05:34 PM   #25
89xj4.7
89xj4.7's Avatar
ok, my xj smells like its running rich, but when i pulled the plugs they look like its running lean, hot....
Old 03-04-2010, 05:41 PM   #26
It has been knocking, so it has been running hot in the combustion chamber. Get your knock sensor working and then see what happens.
Old 03-04-2010, 05:48 PM   #27
89xj4.7
89xj4.7's Avatar
yea it pings like a mofo... soon as the motor cools off in gonna put it on.
Old 04-15-2010, 08:26 PM   #28
rockcrusher
rockcrusher's Avatar
Did it help after you changed the 02 sensor?
rockcrusher is offline   Reply With Quote
Old 04-16-2010, 01:24 PM   #29
89xj4.7
89xj4.7's Avatar
i put the knock sen back in and it fixed it...
Old 04-16-2010, 01:31 PM   #30
CT99XJ
CT99XJ's Avatar
i run Accels. better than the Bosch and Champions. might just be my motor but Champions made it lope like it thought it was a cammed out big block.
98 Grand Cherokee, "Projekt Plush"- 2" of up, 30" Coopers, leather, sunroof, 219k and counting
April 2010/May 2011 Cherokee of the Month
Originally Posted by Buffalo Phil View Post
Originally Posted by lifted1994xj View Post
CT99XJ is offline   Reply With Quote
Go Back   Jeep Cherokee Forum > Jeep Cherokee Forums > Grand Cherokee Technical Forum
OEM plugs, 1997 4.0 willoy Grand Cherokee Technical Forum 4 08-16-2009 11:38 PM
92 4.0 Starts Runs Rough Fuel fouling Spark plugs.Dies No Idle. Pittbullds Grand Cherokee Technical Forum 1 05-21-2009 08:40 AM
Champion Truck Plugs Firewater Cherokee Stock Technical Forum 3 03-31-2009 08:08 AM
Differential Drain Plugs GardenGnome07 Cherokee Stock Technical Forum 7 01-02-2009 11:41 PM
What plugs do you use? Kyle Cherokee Stock Technical Forum 17 11-07-2008 07:56 PM
