Quantcast How much life in a Grand Cherokee? - Page 2
International Jeep Cherokee Forum Community. Everything related to Jeep Cherokees with Gallery, Blogs, and Links.
Cherokee of the Year Winner - minero73mx
Go Back   Jeep Cherokee Forum > Jeep Cherokee Forums > Grand Cherokee Technical Forum
Old 09-05-2009, 10:41 AM   #16
indyjeepcreep
indyjeepcreep's Avatar
2002 WJ
Default 2002 wj
I just turned 157387 on mine.... in the last two years, I've spent $120 in uh oh maintenance..... pretty nice... will run longer than most rigs out on the road....
indyjeepcreep is offline   Reply With Quote
Old 09-05-2009, 10:42 AM   #17
indyjeepcreep
2002 WJ
I just turned 157 K on mine.... love it, runs good.... take care of it and it will last you.
Old 11-21-2009, 10:28 AM   #18
nate dog
I have over 215k and just drove it from F.L. TO M.D. about 1000 miles with no problems except had to replace idler pulley in bum f.... N.C. somewhere
nate dog is offline   Reply With Quote
Old 11-21-2009, 11:27 AM   #19
WJCraig
On The Ban Wagon
WJCraig's Avatar
2001 Grand Cherokee
Unfortunately this is an impossible question to answer accurately. As with every vehicle out there, the factory builds some a little better then others, then different owners drive differently, maintain differently, etc...
My WJ sees more abuse on the trail then one owned by a laid back old man who only drives on the street and drives like it's Sunday every day, and is meticulous about maintenance.
However, it probably sees a lot less abuse then one primarily driven by a young driver who likes to cruise town, get into stoplight battles with whoever he rolls up next to at the red light, and only does maintenance when something goes wrong...
So to answer...how long will it last?
As long as the average automobile from around the same time.
Official Frozen Canuck Member #1
2001 WJ, 4.7L V8, 4.5" Suspension Up, KOR Sliderz, JKS Discos, 32" Mud Shoes, Other Stuff...
WJCraig is offline   Reply With Quote
Old 02-10-2010, 04:19 AM   #20
charlsc
Jeep's existing Cherokee has already proved a big hit with those who would otherwise look to a Land Rover Discovery or something Japanese. It is nice jeep it will last longer.
charlsc is offline   Reply With Quote
Old 04-05-2011, 02:14 PM   #21
li-lannie
1995 Grand Cherokee Lerado
Mine just turned 244,734 runs beautifully. LOVE MY JEEP!!!!!
li-lannie is offline   Reply With Quote
Old 04-08-2011, 07:43 PM   #22
nyghtryder
nyghtryder's Avatar
196k on the zj and 186k on the xj both run great. do your maint.
nyghtryder is offline   Reply With Quote
Old 07-03-2011, 02:42 AM   #23
4x4in
1995 ZJ Grand Cherokee Limited
Mine is at 243k with the 5.2 V8. Starts right up in the -40 weather here in fargo. The all time AWD sticks to the trail even with bald tires. Even the heated mirrors still work. The only problem it is lacking a little power, maybe a clogged gas filter?
4x4in is offline   Reply With Quote
Old 07-20-2011, 11:22 AM   #24
sadass
sadass's Avatar
1998 ZJ 5.9limited
OP. congrats on your WJ, it great rig. To see 150000 Miles on the Odometer is no problem if normal routine maintenance is done.
With your 2001 WJ Grand Cherokee , two common problems come to mind. The fist one you will see if not already is the Door Blend Issue. No this has nothing to do with the color of your doors. If you experience any heating or cooling issues within the cabin air temp no heating or cooling like the controls indicate , then there is a very high chance that you have this issue. My advice now is go to Jeep forum or any other Highly Used Grand Cherokee forum and search for Door Blend. you will see what you are in for. Again, not the end of the world, a Pain in the but yes, but there must be a hundred write up covering what it is and how to address the issue by your self.
The other Problem or issue that has Plagued the grand Cherokees with the AWD or full time transfer cases since back in 1993 and on, is a bad all time 4x4 transfer case. First it was the VC or viscous coupling that would fail and cause the Jeep to lock the front and rear axles together as if it were in Part time 4x4. this is bad on pavement due to the available traction on the road binding the front to rear while turning due to the different distance of the path the two axles travel through a turn. Your Jeep, may be ok if it has the Part time 242 case that allows for a 2wd position. if you have only fulltime 4x4 or awd, you then have a 247 transfer case with a very similar PC (progressive Coupler) to that off the ZJ(93-98) 249. the WJ's(99-2004 ish) 247 can also fail like its predecessor the 249 in the zj
The couplings are sealed units inside the transfer-case and not serviceable. rather then replace the coupling, 99% just put a different case in due to the fact it is more affordable and a better option. most will put in the 242 part time.
a quick test for a bad transfer case, Drive your jeep until it has reached temp. then go to a parking lot and do a figure 8 or a circle. if you can make these tight turns without the jeep binding and hopping with tires chirping, then you have no worries. The CV axles only become an issue if the Transfer case starts to go bad.
Worst case scenario, you spend around 300$ bucks and put the part time 242cae in like most of use have. Again , there are a ton of write ups on that swap too!
Good luck my fellow Jeeper
98.5.9Limited.242w/ Aussie 4Locked +Yukon 4.52
sadass is offline   Reply With Quote
Old 07-20-2011, 02:32 PM   #25
stamp
muddin moderator
stamp's Avatar
91 cherokee
holy old thread batman
original post is just under 2 years old...
chris
1985 Dodge dually (6-8mpg dd and tow rig)
1998 jeep xj (gf's project Dee Dee)
1965 Chevy 1/2ton for sale or trade
raceing is you and your car against the clock not the other car , in fact there are no people in the stands , no one else is at the track but you and the tree
stamp is offline   Reply With Quote
Old 08-26-2011, 03:10 AM   #26
ldub100
ldub100's Avatar
1991 Cherokee
I have 200K on my 4.0L and still ticking (literally).
ldub100 is offline   Reply With Quote
Old 08-26-2011, 07:25 AM   #27
2001 Cherokee
oe kame ngenga
http://www.ironman4x4fab.com/index.html
Old 08-26-2011, 02:38 PM   #28
CT99XJ
CT99XJ's Avatar
1999 Cherokee SE
Old thread is old.
However: My 98 Grand has 219,9xx on the 4.0 and it runs great. 90k is barely broken in
98 Grand Cherokee, "Projekt Plush"- 2" of up, 30" Coopers, leather, sunroof, 219k and counting
April 2010/May 2011 Cherokee of the Month
Originally Posted by Buffalo Phil View Post
Originally Posted by lifted1994xj View Post
CT99XJ is offline   Reply With Quote
Advice: Cherokee or Grand Cherokee? fraserwag General Vehicle Forum 20 02-28-2010 01:52 AM
2011 Grand Cherokee PurpleCherokee Grand Cherokee Technical Forum 19 04-18-2009 10:35 AM
Grand cherokee seats in XJ ? Rmart30 Cherokee Stock Technical Forum 3 02-19-2009 07:04 PM
help for my grand cherokee sid8845 Grand Cherokee Technical Forum 2 01-23-2009 09:37 AM
Grand Cherokee Lifts flexyxj Grand Cherokee Technical Forum 5 11-29-2008 12:29 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd
Jeep Wrangler Forum
Jeep, Wrangler, Cherokee and Grand Cherokee are copyrighted and trademarked to the Jeep/Chrysler Corporation.
CherokeeTalk.com is not in any way associated with Jeep or the Chrysler Corp.
