Official Stupid Question Thread - Page 57
Go Back   Jeep Cherokee Forum > Cherokeetalk.com General Forums > General Discussion
Old 05-06-2019, 11:44 AM   #841
1_2_XjU
1_2_XjU's Avatar
Originally Posted by 4.3L XJ View Post
When you replace motor mounts, unless you have the engine out, it is better to have the rear of the assembly secured to the cross member so you can just drop the engine down after replacement
That was my thinking - it would be unstable to prop the motor if the back end was not secured.
So I’ll either set the crossmember back on and do them now, or wait till I get the trans back in.
Jack - 99 XJ AX15 chili pepper red
This goes out to everybody.....ready?
FLEX YOUR HEAD!!
Toothless - 02 WJ
Sally - 79 Wagoneer
1_2_XjU is offline   Reply With Quote
Old 05-07-2019, 04:29 PM   #842
Not sure where you will find the info, (u-tube) but you only need a 2 by 4 and a floor jack not sure which side you start with but you replace one side at a time. When I replaced my mounts I just loosened the rear tranny bolts but did not have to remove them.
Really a pretty easy job once you dive into it. If you are using brown dog mounts (or similar mounts) make sure once you tighten the bolt through the bushing, back it off about 1/4 to 1/2 turn. Others wise you will have excess vibes.
JandDGreens is offline   Reply With Quote
Old 05-07-2019, 08:41 PM   #843
DaingMaing
DaingMaing's Avatar
Been looking around on rockauto and because I couldn't find them doesn't mean they don't exist. I don't recall them at all when I pulled the WJ knuckles in the PnP JY.
Do the WJ grand's have front disk brake dust shields?
Can't seem to locate an OEM pair... I'm sourcing the last of the miscellaneous parts I need to complete the rebuild and steering overhaul. I can find the rear D44a's all day long, but not a single one for the front. Did the akebono style calipers prevent the use of one?!?
If you find any of my posts or threads with a broken Photobucket link, PM me; I'll re-up the photos!
Modified Grand Cherokee of The Month
- October 2013 - March 2016 - August 2017 -
DaingMaing is offline   Reply With Quote
Old 05-08-2019, 05:38 AM   #844
1_2_XjU
1_2_XjU's Avatar
Thanks - yeah not too worried about the actual task, more worried about trying to do it with the trans pulled would leave no rear support, which could potentially result in an “oh s***” situation when the motor is supported only by one mount and one 2x4 on a jack. It will be easier and safer to do them with the trans still in and supported.
FLEX YOUR HEAD!!
Toothless - 02 WJ
Sally - 79 Wagoneer
Old 05-08-2019, 07:59 AM   #845
I don't think they do but will crawl under the Overland when I get home. Sad part is I've changed brakes on my WJ since 2002 and i don't remember that. I think the ole'timerz is setting in.
APRIL 2019 Stock Cherokee of theMonth
Old 05-08-2019, 08:54 AM   #846
Yes, they have dust shields
230 hp 4.3L Chevy
Built 4L60E with manual lockout
Atlas 4 speed
Griffin radiator
On board air
Warn 9.5ti on custom bumper
7.5" RE front and bastard pack rear on custom long arms
31 gal. gas tank
Old 05-16-2019, 08:38 AM   #847
1_2_XjU
1_2_XjU's Avatar
Source for vacuum elbows for manifold? Think I tried looking once but it was harder than I thought it would be to find the correct pieces.
FLEX YOUR HEAD!!
Toothless - 02 WJ
Sally - 79 Wagoneer
Old 05-16-2019, 10:22 AM   #848
Ralph77
Think a '99 is like an '00? I have 3 on the side. Never messed with the one closest to the firewall but have with the front 2. The one closest to the radiator in my Jeep. The nipple on the manifold is the same size as the plastic line. So just a piece of vacuum hose. The one in the middle is a different story. Nipple on the manifold is a different size then the plastic line. I found a Dorman part that is tight. Actually for a Ford. Going to have to look up the number if you are interested. Will get back to you.
Ralph77 is offline   Reply With Quote
Old 05-16-2019, 10:40 AM   #849
Ralph77
Dorman 46022. The one with the Van Halen looking figure on it. LOL.
https://www.dormanproducts.com/p-32422-46022.aspx
Old 05-19-2019, 12:18 AM   #850
ridingmyfabcar
Love reading this thread! When would jeep invent an automatic door that would just open just like the doors in some malls..don't wanna touch the handle it's kinda full of germs
ridingmyfabcar is offline   Reply With Quote
Old 05-19-2019, 01:49 PM   #851
1_2_XjU
1_2_XjU's Avatar
When there’s a “Tesla Jeep” would be my guess.
Actually i don’t wanna touch the handle cause my hands are all covered in oil and crud
FLEX YOUR HEAD!!
Toothless - 02 WJ
Sally - 79 Wagoneer
Old 05-21-2019, 07:48 PM   #852
Id focus on building my immune system then. But if thats out of reach, scissor door kits seem like they can be cobbled onto anything these days. I think ive seen remotely opened ones.
Ford uses the foot-sensing release on rear hatches for some models, i see no reason it couldn't be applied to side doors with some ingenuity and a few more moving parts. ACTUALLY: a google search shows that aftermarket kits are sold to be installed on all kinds of cars. Do it, and let us know how it works out.
September 2017 Modified Cherokee of the Month
2001 XJ: 4" lift (MetalCloak CAs, Tuff Country coils, IRO aal), 31x10.50r15 Cooper STT Pros, TruTrac 4.10 front, Spartan locked 4.10 rear, SYE, custom gas tank skid, Durango steering box, Yakima roof rack on custom bars, WickedBilt LED lighting, 784 injectors, Afe intake, OBA, more soon!
Old 07-11-2019, 03:08 PM   #853
1_2_XjU
1_2_XjU's Avatar
I replaced my power steering pump - swapped pulley from the old one - and now I’ve got Vicious belt squeal.
Did I do something wrong?
Is it possible I pressed the pulley on too tight or not tight enough, and now i have pulley misalignment?
FLEX YOUR HEAD!!
Toothless - 02 WJ
Sally - 79 Wagoneer
Old 07-11-2019, 07:36 PM   #854
You can look across the pulley and visually check the alignment. It would be pretty obvious. The belt squeal is probably the belt not tight enough. When you push down on the belt it should only deflect about 1/2" .
Old 07-11-2019, 07:59 PM   #855
1_2_XjU
1_2_XjU's Avatar
it looks good while its spinning, no wobble.
Belt didnt squeak ever before.
This is the WJ 4.7, so its the automatic tensioner.
Well, i ordered a new belt anyway, so we'll see if that makes any difference.
FLEX YOUR HEAD!!
Toothless - 02 WJ
Sally - 79 Wagoneer
