2000 jeep cherokee plugs - Page 2
Go Back   Jeep Cherokee Forum > Jeep Cherokee Forums > Jeep Cherokee Stock Technical Forum
Old 11-19-2019, 10:08 AM   #16
Ralph77
Originally Posted by Fluxcore8 View Post
Ralph sorry, I meant the intake manifold and exhaust manifold, thanks
You are going to have to google that.
Never done it and not sure of the order.
I want to say that you will take off the intake manifold first though.
Ralph77 is offline   Reply With Quote
Old 11-19-2019, 10:45 AM   #17
Fluxcore8
Yes, there no order I can't see or feel the bolts or nuts. as I stated I removed the abs pump & bracket, maybe the steering column being removed also, If you don't have a better procedure.
Fluxcore8 is offline   Reply With Quote
Old 11-19-2019, 08:41 PM   #18
Pretty sure the intake and exhaust manifold share the same bolts. they kind come off together.
Gotta reach under the intake to find the bolts. Here is a video:
Old 11-26-2019, 09:07 AM   #19
1_2_XjU
1_2_XjU's Avatar
Some of the manifold bolts can be tricky to access. I did mine pretty easily, but all other parts that could have been in the way were already removed - steering pump and gear box, and all front suspension and axle. And it was still tricky.
One tip for the rear lower bolts is to use a socket extension through the holes in the wheel well, with wobble sockets.
When installing, make sure everything is seated completely, and tighten all bolts in proper sequence to proper torque spec.
Jack - 99 XJ AX15 chili pepper red
This goes out to everybody.....ready?
FLEX YOUR HEAD!!
Toothless - 02 WJ
Sally - 79 Wagoneer
1_2_XjU is offline   Reply With Quote
Old Today, 12:06 PM   #20
Fluxcore8
https://youtu.be/tow2JQhvYak
I tried with a straight extension and couldn't get on the bolts the intake is lower than the bolts, if exhaust comes of first I'll use a wrench, it too tight to get in there now. it fuel injection also
Old Today, 04:04 PM   #21
Your probably gonna have to use a universal.
