Can anyone tell me where I might find a 1996 Cherokee Country Heater Blower wiring diagram. As far as I can tell the 1996 doesn't have a relay. The speed selector switch and wiring are fries, can't tell what color the wires were.
This is what I have been looking for, thank you very much. I bought this jeep new in 1996 It has been a great car. The HVAC has been a problem for years, the blower motor speed switch has burned out several times. Very week point in the HVAC wiring system, every component in the system is in very good condition. I would like to design a circuit and switch to take the heat. I thank you very much for the information.
You are welcome. The blowers in these things take a TON of power. If you are savvy, you could run a new circuit, with a larger fuse, larger wires and a relay. I would take a look at all the connections and your grounds. make sure they are pristeen!
