Tested injectors with ohm meter 13.8 which is correct from what I can find. So what's next?From what you say, probably. Change injectors and start it and see what code you get
well the tabs will not fold down it leaks and it took prying against the fuel rail and pulling with all I had to get it to come offSo you know the connector is shot?
Recently replaced my supply line to the fuel rail due to a bad connector. Found what I needed at autozone. Wasnt fun to replace, but it doesn't leak and stays connected now.ok on the same note I think fuel line to fuel rail is junk how do I repair that the push on stainless connector
