1 - 13 of 13 Posts
HI , wondering what the best kit is to repair a knocking transfer case shift linkage??? 2000 Cherokee Sport 4wd.
First, welcome to cherokeetalk! Well, two questions: what exactly is transfer case linkage knocking? And what do you mean by kit? Do you mean it's not staying put?
It's a 2000 XJ, but are you lifted, stock? What transfercase do you have?
It is stock, no lift. From what I have read the knock or rattle under the hump is a worn transfer case shift linkage bushing. So, I am looking for a kit before the rattle comes to it not staying put..
Thanks for the info. If you feel like upgrading, there are a couple aftermarket shifting linkages available. Azzys is the big one. I asked about stock vs lifted because sometimes a lifted jeep doesnt like to shift well.
If you are just looking for a bushing, I'd try Napa or Oreillys. Sorry I'm not familiar with a specific bushing kit.
We do have a napa. auto zone, advanced etc. I saw a single bushing on one and a kit by crown automotive on another. Trying to see what is best and there are always alternatives but I could not find any threads.
I will look at that azzys linkage, not sure what looks like yet but I got 20 years on this one so I will stay stock i guess.?? Thanks, Jeff
Discussion Starter · #7 ·
Here is the kit from crown auto. I read reviews and looks like maybe I will just find a bushing a the local store. Most say the green bushing is all they use.
Some say the bushing is rock hard and they needed heat to fit it?? Anyone use this kit?
Just an FYI, the factory setup connects to both the body and T-case. These jeeps are unit- body construction. Which means the body twist a little when going over bumps and holes. And the engine, transmission/T-case (powertrain) rotate under normal operation. If you have ever had the hood open when someone revs up an engine, you can literally see the engine move. Because the linkage is connected to the body and the power train, it can easily bind up and not want to engage or disengage. The Azzys setup moves all the connections over onto the power train and eliminates the chance of binding. I've been using his set up for years and I am very pleased.
Discussion Starter · #9 ·
Well I have a few choices anyway.. What you talked about would explain why it comes and goes. Certain angles in the road must be trigering that frame / body situation causing the rattle.. Thanks..
If you’re going to mess with fixing the t-case linkage at all, I’d highly recommend the Azzy’s or Boostwerks linkage. A very simple system that is a great upgrade for not much money or effort. I installed the Boostwerks.
No. Everything is tight and secure. Haven't thought about it though. And since it still works, I guess I'm good.
1 - 13 of 13 Posts
