'96 XJ here and she's due for some maintenance
1) My steering has been misaligned for a while now pulling fairly hard to the right. What part of my steering is causing this and how to adjust? I won't get this perfect but any improvement would be great
2) How do I find just the headlight harness for this kind of bulb? 3 prong, pic below. Every search I do for H4 hella harness gives the whole thing and I just need the parts that plug into the bulbs w/ pigtails.
3) Broke the dang rear wiper assembly the other day and need to find replacement parts. Thing is I hadn't paid any attention to how this broken part (pic below) was before it was broke so I don't know how they go back together, or if I can just order the small broken part or the whole arm assembly that comes with it. Also wondering what it's called and where to look for it.
Thanks friends, appreciate the help.
229544
229545
The answer to your first question isn't exactly straight forward. First get an alinement done. Then make sure your castor angle is 5° or in that ballpark. Most lifts mess up the castor angle. If you fix that and it still does, then there is a difference in castor angle from the factory that makes it pull slightly to the right. You can correct that with offset upper ball joints
What kind of harness are you looking for? stock, upgrade?
Just get the whole arm from a place like NAPA
Thanks for the wisdom 4.3...wait 4.3? Nice. I'll follow your advice on the steering and luckily I got links now to the parts I need. Didn't know there was a ceramic upgrade for the H4 harness but luckily I found one.
Good luck
