1 - 20 of 297 Posts
i picked up this 1995 jeep cherokee sport 4.0 auto for $400. it has not ran in over 5 years. it looks pretty bad but the guy i bought it from was going to sell it for scrap. so i just made him an offer. he said it was running when he stopped driving it so i figure i could fix it or part it out.
i pulled the tank and it was gone beyond repair. so i ordered a new tank and hoses. the fuel sending unit was gone. i will try and use on off a 93. i cannot find one from a 95.
right now i am waiting on the mail man to bring me my parts and i will see if i can crank it up.
Yup, looks same as mine, but mine are shiny :D
Good start, your fuel sender actually looks better than mine did when I pulled it. I was able to repair mine but am unsure of it's accuracy.
Ok
mine fell off. My run it without a gauge for a while
I noticed all the gunk was not rust and it would brush off. So I cleaned everything.
The send unit was missing wires
I am still wondering if a sending unit from a 93 will work in my 95
Administrator
It should since you're still post-Renix but pre-OBD2.
Might want to change all of the fluids since it has been sitting a long time.
thanks
i agree with you. yesterday i took off the fuel filter because i was going to blow out the fuel line with an air compressor and too because i have ordered a new fuel filter. well to my surprise the gas looked very clean. it was nothing like what i found in the tank. i actually felt good about that.
but yes i will change the oil and probable run it a 100 miles or so then change it again.
probable put a new water pump thermostat and radiator too.
i have replace the radiator in some of my older trucks and noticed a great difference it the way it cools.
i am out of town but i have been getting emails that parts are arriving at my house. i really really want to see it i can fire this thing up this weekend.
the gas tank i order looks like it had not been painted. so i plan on painting it and putting that thing in.
If it needs painting, you should coat it with something better than the first can of paint you find. Try a chassis saver or undercoating so itll last longer and you wont have to worry about rusting later.
Discussion Starter #12
Ok thanks
I bought some primer and some paint. Not sure if that’s heavy enough. The old tank came in a plastic container so I was going to try and reuse that too
If you insists on using paint, then use good (self-etching) primer and follow-up with good paint. After that has had a week or so to cure, coat it with undercoating or bedliner or something tougher to avoid general rusting and rock chips, scrapes, etc.
Discussion Starter #14
Ok
Now that I think about it. I have some bead liner stuff. Do you think that stuff is
Good to use
Discussion Starter #15
#36
40vern
Registered User
1999 XJ Cherokee
Profile
Gallery
Classifieds
My Jeeps
iTrader Rating
Well I installed my sending unit without the sending unit. Just a new pump. New tank. Replaced all the rubber fuel lines and return lines. Replaced the runner vent lines on the tank. Replaced the fuel filter and the fuel regulator. Then I fired that baby up. It is running.
I just stopped working at 7. I wanted to try and drive it but I saw a fuel leak at the fuel filter. I will try and see. What is going on with that tomorrow. Right now I am very happy.
I will worry about a fuel gauge later
Discussion Starter #16
#36
40vern
Registered User
1999 XJ Cherokee
Profile
Gallery
Classifieds
My Jeeps
iTrader Rating
You could eliminate some of the aged look by pulling off the rest of the red pinstriped moulding. Imo it doesn't serve much purpose anyway.
1 - 20 of 297 Posts
