Would the 86 have 4.10 gears in it? I think they all did when they came with the v6 did they not as a rule of thumb.
I found a beater for 150 bucks. was thinking it would be a good gear swap for that price. but its a long drive just to see if it did have or not.
Not necessarily...
In 86 the same range of gear ratios was available... With the largest selection of V-6 and auto trannies still getting3.55's
the parts xj i had had the v6. i took the axles from under it. it had 3.73. after i installed it i broke the ring gear, with the open diff. no locker. if you are going to do an axles swap, try to spend the $ on a good axle. the d 35 is junk. and the older d30 xj u joint was small. i broke it 3 times and it took out the axle ends.
