1 - 2 of 2 Posts
Hi all,
I have just bought a 94, 4cyl petrol cherokee with a couple of faults!
1, when I engage 1st gear there is a slight knock. I have checked the amount of play in the rear prop shaft and that seems ok but the front prop shaft has half an inch of play when i turn it left/right. Can any thing be done or am I looking in the wrong place?
also the transmission whines a bit in 1st and 2nd gear is this normal?
and last of all, when i select reverse gear from a standstill i have to pump the clutch pedal a couple of times to engage reverse, I have looked where the slave cylinder is and it seems to be inside the transmission case? there are two pipes exiting from a large oval rubber boot. Can i remove the boot and then the slave cylinder?
Thanks.
1 - 2 of 2 Posts
