1 - 10 of 10 Posts
96 Cherokee XJ
The description in the ad: $600. Radiator leaks, gas tank leaks if you put more than 7 gallon, not firing on all cylinders and possible transmission issues but could be do to the radiator leak because it runs hot.
Here's a few photos, as advertised.
Wheel Tire Automotive parking light Automotive side marker light Vehicle
Automotive parking light Car Vehicle Land vehicle Plant
Automotive parking light Vehicle Automotive side marker light Car Automotive tail & brake light
Wheel Tire Automotive parking light Vehicle Car
Vehicle Car Motor vehicle Window Car seat cover
Car Vehicle Plant Motor vehicle Car seat cover
96 Cherokee XJ
Discussion Starter · #2 ·
Progress will come slow for a couple months, due to an injury, so I dropped it off at a very capable mechanic/fabricator. This was moving day.
Tire Wheel Automotive parking light Car Sky
Automotive parking light Car Tire Wheel Automotive side marker light
While my mechanic goes through it, repairing the fuel system components, and head gasket, or head, I'll gather parts.
96 Cherokee XJ
I forgot to tell the short story of how I managed to pick this up. When I saw the ad, I quickly went through the photos, then messaged the seller "Do NOT accept less than your advertised $600. I'm interested, and will not talk you down." The End.
Interior is nice, straight body. It was worth every penny
Reactions: CoalCracker
Congrats. I have an 86 two door
They should be the same as for all the XJs up to mid 96. I am not sure if post 96 are the same.
96 Cherokee XJ
Discussion Starter · #9 ·
Head was cracked.
Automotive tire Green Light Wheel Rim
Installed a brand new head.
Vehicle Motor vehicle Car Hood Automotive design
Next; fuel tank, pump, lines, rail, injectors, water pump, radiator, hoses, then 2 inch lift, Iron Rock front D ring/tow mount, and Mud Claw tires.
1 - 10 of 10 Posts
