So about the misfire, I’ve noticed, I can go out and start the jeep and it’s fine, put it in gear and with in 2 mins of driving it throws the PO301 code, I can stop turn it off to clear the code with my computer. I then start it back up and drive any distance/amount of time without it throwing the code again until I shut it off and start it back that’s after any amount of time being off. I have on several occasions left the computer hooked up to watch live data to see if I see anything and sometimes not always it will show PO301 code as pending but not thrown yet and some times it’s not even pending. The misfire isn’t bad at first but after driving for long period of time it gets somewhat worse, throttle response get slightly hesitant,a little jerky feeling setting at a red light, vibrates exhaust very loud and twice I’ve heard the notorious 4.0 knock sound. (only after running for really long period). I was hoping running it might break up some carbon build up that sea-foam top engine cleaner didn’t get and possibly clear up itself. After it’s at temp for 20mins or so you can clearly hear the misfire but again gets worse with time. If I’m throttled up at RPM higher then idle the misfire sounds gone and it sounds amazing and runs absolutely amazing when like in passing gear. Yesterday after a drive I decided to mess with the injector 1&2 while running I moved them around and got not change, I then unplugged them an my computer picked up an open circuit on both injectors but as far as running you would have never knew I in hooked them, I got an amazing deal on this rig and I’ve put money in parts, and a whole lot of labor, I’m almost to the point of posting for sell, I love working on vehicles and learning new stuff but I have exhausted my entire mental book if knowledge, I bought an 99 last week with a leaky trans and good motor with 123,xxx miles I could swap but I had to tear apart a super clean 99 that’s just needs a trans filter and gasket, thanks everybody for the help I hope I covered everybody questions in this
