Jeep overheated and shutdown on me due to water pump failure. I assumed cracked head or blown headgasket so I took the head off to check. I wire brushed it and looked closely for cracks but did not see any. I cleaned it up put on a new gasked( the old one did look like it had failed and was allowing blowthrough ( you could see how an area on cylinder 3 was shiny clean from the steam) on startup it ran better but it still had a rough idle. It now codes P0505 and high battery temp ( my battery temp sensor wires were cut and it looks like they've been cut for a long while). I have changed:
Distributor cap
Distributor rotor
Spark plugs
Ignition coil
Map sensor
Idle air intake valve
I also cleaned the throttle body and changed that gasket
I cannot find the issue and I am starting to think that it could possibly be that my head was warped or a microcrack but yesterday the Idle was fixed for one trip to raising canes. It idled smooth but instead of a rough idle it had a delayed return to idle.
I hope you all can help
Distributor cap
Distributor rotor
Spark plugs
Ignition coil
Map sensor
