Status
Not open for further replies.
1 - 20 of 29 Posts
Things like doors, hoods, axles, leaf springs etc. will not be shipped, and are local pickup only... Will drive to meet someone within reason. All other things that will fit on a UPS truck can be shipped. NO AXLE SHAFTS. I will update the original post with other things as I find them.
98 ZJ, 247k on 4.0, 42RE: All driveline components up for grabs excluding driveshafts, 242 T-case and axle shafts. NO LIFT COMPONENTS ARE FOR SALE. All interior pieces up for grabs. Sandstone in color.
99 XJ: 165k on 4.0, AW4 has 100k on it. 231 T-case, can use a front output bearing. Locked 29spl. 8.25 with Riddler diff cover, 3.55's, Aussie. HPD30, 3.55's w/D35 Aussie, knuckles reamed for UTK one-ton steering (no axle shafts). Skyjacker 3" coils, 3-3.5" bastard pack leafs. All interior pieces up for grabs, crank window doors set up for doorless. CARR light bar. Factory option Alpine 6-disc changer with radio transmitter and control. Taillights good, hatch good with a couple dents. Green. Header panel, front axle shafts not for sale. Check build thread:
http://www.cherokeetalk.com/forum/f26/ct99xjs-build-birth-projekt-swamp-thing-12561/
Other stuff:
ZJ/XJ Overhead console: Grey in color. mild dirt but nothing that can't be taken out. Complete, display functioned when pulled out.
Second set of ZJ doors, minus driver's door. Sandstone in color. glass good, paint good. No door cards.
XJ hitch, Class III
TJ/ZJ rear upper control arms: Clayton style, fixed Johnny Joint with adjustable Johnny Joint on other end. No adjuster, but other JJ is complete. Bare metal, $100 shipped.
Any questions on parts available off either rig, post here or send me a PM.
:thumbsup:
quicksilver said:
What are you looking to for the 8.25? Axle shafts included?
Shafts are included. I need to clarify the OP- no shafts sold separately.
PM me an offer, we can go from there.
CT -
How many miles on the 42re?
It's the original trans, so 247k. Could use a TC but the rest of the thing functions perfectly. Has a brand new output seal.
how much for the HPD30 front axle from the 99 XJ? u can keep the knuckles and brakes to keep the cost down. you are about 2 30 min away so i could do local pick up.
Discussion Starter · #8 ·
Not going to split up axles, sorry.
JeeperDk, I'll reply to your PMs shortly
Hello...
Would you happen to have the driver's side taillight assembly?
22973 is my ZIP...
Thanks!
Discussion Starter · #12 ·
I'd rather not split the taillights. I do have both, though.
Discussion Starter · #14 ·
Located in CT, not pulling the motor though. I'll pull pieces off but the motor isn't going to be taken out of the vehicle.
Discussion Starter · #17 ·
Because shipping a motor is worth more than the motor itself, sorry. Not happening.
Discussion Starter · #19 ·
Fender is cut wide for 35's, stock bumper ends are long gone, SE models didn't have door trim
1 - 20 of 29 Posts
Status
