I found another issue that needs to be dealt with... my a/c compressor just started making a high pitched whining/howling noise! It kinda sounds like the noise you'd get in your car stereo from running unshielded ignition wires, only much loader and speakers aren't required!!!
Honestly, i feel like i've got much bigger fish to fry with my XJ right now, mainly replacement of my Exhaust Manifold! I'm just trying to keep my daily driver, a daily driver!
I was just going though the recent "A/C Delete" post, i don't really want to give my a/c the axe, i just need to keep my Cherokee running.
I am just curious as to what i can do for a 'quick fix' until i can deal with this later? I assume that my Compressor will seize-up soon and i will spin a belt! I was considering unhooking my Compressor and replacing my belt with a Non-A/C belt, or maybe hitting the J/Y and grabbing another compressor, installing it, and get it re-charged later?
I am open for suggestions on this one!!! :bow:
:brickwall:
Discussion Starter · #2 ·
Could it be the Compressor Clutch and/or Bearing making all this racket?
It seems easier to swap these parts out, than the entire Compressor, ya know? :dunno:
:brickwall:
I'd say get one from a junkyard for now... it sounds like its the pulley on the A/C
Anyone know how labor intensive (Clutch)/Pulley Replacement is? What do you think that my plan of attack should be?
I'm considering a New Bearing and just grabbing a (Clutch)/Pulley off of another one at a J/Y... :dunno:
:brickwall:
Always start with the easiest thing and work your way to the most difficult/expensive...
When was the last time you replaced that belt? If it's showing signs of age/wear (cracking along the grooves), then you should replace it - the noise is telling you that.
If it was recently replaced, are you sure you tightened it enough? A new belt needs to be tightened to 180 lb/ft - 200 lb/ft, and a used belt should be at around 160 lb/ft - 180 lb/ft (FSM for 2000 XJ).
I guarantee that this will fix your problem. If everything is within spec, then move onto something else, like a pulley/bearing issue.
Discussion Starter · #8 ·
YO!!! Tighten your belt. My 99 Xj did that and that did the trick. Your belt is loose and is slipping on the compressor pulley. Good luck!!!!!!!! (btw, it is loud as sh*t huh/., lol)
I wish it was just that easy... that's pretty much the first thing that i checked. My belt is only about a month old and VERY well adjusted. Maybe even a little bit to tight and putting stress on my a/c pulley. Unfortunately, it's not that high pitched belt squeal that we know all so well here. More of a howl than even a whine and standing there right next to it, you can tell that that it's in the compressor itself. :dunno:
I will be swapping-out my 'spare' Gates belt and installing a brand spankin' new Goodyear Gatorback when i get this issue fixed. That'll definitely do the trick, right? ;)
