same here. got it all dusty during the dry summer months. I run regular paper filter now. filters better.i ran a K&N drop in and it coated my throttle body in dust in less than 6 months. i switched back to paper and threw the K&N in my stepdad's DD 96 XJ. i didnt notice a difference going back and i have quite a few bolt-ons.
and yes, it was oiled properly.
I have heard reports from others with very similar results to the ones you describe which is why I have never ran one.i ran a K&N drop in and it coated my throttle body in dust in less than 6 months. i switched back to paper and threw the K&N in my stepdad's DD 96 XJ. i didnt notice a difference going back and i have quite a few bolt-ons.
Elaborate on the sock part, what exactly are you talking about?A K&N filter flows well, it does not filter well. Throwing a sock (not an actual sock) over it can help somewhat with the lack of filtration. There's lots of SOAP (spectrometric oil analysis program) results out there showing how big of a jump in silicon contamination a K&N causes over a paper filter.
We run K&Ns (AFS) on the helicopters (really big ones) simply because they filter much better than what was there before (chicken wire, basically) but cause very little restriction in airflow. When they get dirty, they restrict much more and engine performance will suffer noticably. But we can clean them, which is better than other filters which would need replacing (which could be logisitcally impossible).
AEM makes a dry cleanable filter that flows better than a paper element, and probably is on par (or better) than the K&N. They might not make a drop-in replacement though.
I think he is talking about this:http://www.knfilters.com/wraps.htmElaborate on the sock part, what exactly are you talking about?
x2. But I also run a FRAM oil filter. GOOD HEAVENS!I run K&N stuff in all my vehicles. I like them feel they make a difference. I have never had a problemn with one.
True, but you could spend a little more and never have to worry about buying another one. Ever. :dunno:IDK I just cant see spending all that much for a filter when I can get a paper one for 3$ and keep a spare.
But the dust issue, cant be good for water intake either.True, but you could spend a little more and never have to worry about buying another one. Ever. :dunno:
IDK Maybe I will give one a try, we will see when I get to the parts store.I would think the oil helps catch a lot of dust (hence the filter getting dirty and needing cleaned) and it's not gonna let any more water in than a regular paper filter I wouldn't think.
But to each his own. I run one; never had any problems, only improvements. The top side of my air box is always clean as a whistle.
