Bought a 2021 Jeep Cherokee 3 weeks ago. When the temps went to -20+ below zero it had a tough time starting even when I turned off everything I could find to lessen the pull on the battery. It came with a battery with 700 amp cold crank rating.
Had the battery tested and it was good. But I need the thing to start well. So, I bought an 800 amp AGM battery. It's working well.
Not sure if being tough to start is going to be a trend? Anyone hear anything like this?
Glad that fixed your cold start problems. I have older stuff, but use Optima batteries. Basically they are not a lead acid set up, but just six big capacitors. They work well with heavy loads and charge up really fast.
Reactions: Hayhauler
If upping the CCA worked then great. Just to be clear, newer vehicles all operate on a timed starting cycle. I'm just checking to make sure you know that and that the car may crank for a moment longer than an older vehicle you are used to.
This applies to all temperatures but cold would probably exacerbate the problem.
Good to know. It started and stopped repeatedly and would eventually take. I wonder how hard that is on the starter and battery.
Its not great for it. If you had to cycle a couple times then yeah, its hard starting and should be firing quicker.
