Status
Not open for further replies.
1 - 1 of 1 Posts
*All Available XJ Suspension Systems*​
*Please Note*
1. The available tire clearance for each lift does not include any trimming that may be done. Those suggested sizes are for stock fenders and you have the potential to get a much bigger tire size if you do a little trimming.
2. The links provided are not necessairly the best available prices but instead links to give an example as to what the exact lift is that your looking for
2-2.5 Inch Lift Options
RE6160 XJ 2" Budget Boost w/shocks
Tire Clearance: 30x9.50
Includes: Break Lines, AAL, Spacers, and Shocks
JeepinOutfitters - Rubicon Express XJ 2" Budget Boost w/shocks, RE6160
OME 2" Suspension Kit, Cherokee, 1984-01
Includes: Bumpstops, Full Leaf Packs, Coils, Shocks, JKS Quicker Disconnects
JeepinOutfitters - OME 2" Suspension Kit, Cherokee, 1984-01, OME-XJ2
Superlift 2.5" Suspension lift, Jeep XJ Cherokee
Includes: Coils, Lower link arms, AAL, and Shocks
JeepinOutfitters - Superlift 2.5" Suspension lift, Jeep XJ Cherokee, SL-K369
Rustys 2" XJ AAL Kit
Includes: Coils, AAL, and Shocks
Rustys Offroad:
Rough Country 1.5" Suspension Kit
Includes: Coils, Shackles, and Shocks
Jeep Suspension Lift Kits
Rock Lizard Fabrications 2" AAL Kit
Includes: Coils, Long AAL, Leaf Spring Clamps, Center Pins, and U-Bolts
Lizard Lift Kits
Rock Lizard Fabrications 2.5" Leaf Pack Kit
Includes: Four Leaf Spring Pack, Coils, Long AAL, Spring Isolators, Spring Clamps, Center Pins, and U-Bolts
Lizard Lift Kits
Skyjacker 2 in. Poly Value Kit
Includes: Poly Spacers, Bumpstops, Shackle and Nitro Shocks
http://www.4wheelparts.com/PDT55375.aspx
Rustys 2" Budget Boost w/Shackle
Includes: Poly Spacers, and Shackle
Rustys Offroad:
Rustys 2" Budget Boost w/AAL
Includes: Poly Spacers, and AAL
Rustys Offroad:
3-3.5 Inch Lift Options
RE6030 XJ 3.5" SuperFlex kit w/leafs
Tire Clearance: 31x10.50
Includes: Gen2 Disconnects, Coils, Bumpstops, Leaf Spring Pack, Rear break line, U-Bolt Kit, and LCA
JeepinOutfitters - Rubicon Express XJ 3.5" SuperFlex kit w/leafs, RE6030
RE6010 XJ 3.5" SuperFlex kit w/aal's
Includes: LCA, Coils, Bumpstops, AAL, and Shocks
JeepinOutfitters - Rubicon Express XJ 3.5" SuperFlex kit w/AALs, RE6010
RE6025 3.5" XJ Super Ride w/ Rear Springs
Includes: LCA, Full Leaf Packs, Coils, and Rear Break Line
JeepinOutfitters - Rubicon Express 3.5" XJ SuperRide w/leafs, RE6025
RE6020 3.5" XJ Super-Ride Kit
Includes: LCA, AAL, Coils, and Rear Break Line
JeepinOutfitters - Rubicon Express XJ 3.5" XJ Super-Ride Kit, RE6020
OME 3" Suspension Kit, Cherokee, 1984-01
Includes: Shocks, Full Spring Packs, Coils, and JKS Quicker Disconnects
JeepinOutfitters - OME 3" Suspension Kit, Cherokee, 1984-01, OME-XJ3
Rustys 3" Spring Pack Kit
Includes: Coils, Full Spring Packs, Break Line Relocation Kit, and Shocks
Rustys Offroad:
Rustys 3" XJ Add-A-Leaf Kit
Includes: Coils, AAL, Break Line Relocation Kit, and Shocks
Rustys Offroad:
Rough Country 3" Suspension Kit, Full Spring Pack
Includes: Coils, Full Spring Pack, and Shocks
Jeep XJ Suspension Lift
Rough Country 3" Suspension Kit, AAL
Pro Comp 3" Suspension System
Includes: Coils, AAL, Break Lines, LCA, and Adjustable Shocks
http://www.4wheelparts.com/PDT1764.aspx
Includes: Coils, AAL, Break Lines, LCA, and Non Adjustable Shocks
http://www.4wheelparts.com/PDT1566.aspx
Rancho 3 in. Suspension Kit with RS5000Shocks
Includes: Coils, Full Leaf Pack, and Shocks
Rancho Complete Suspension Systems
Skyjacker 3 in. Standard Kit w/AAL
Includes: Coils, AAL, and Hydro Shocks
http://www.4wheelparts.com/PDT54900.aspx
Skyjacker 3 in. Standard Kit w/ Full Spring Pack
Includes: Coils, Full Spring Pack, and Hydro Shocks
http://www.4wheelparts.com/PDT55240.aspx
Full Traction 3.5" Kit
Includes: Coils, Quick Disconnects, Rear Break Line, Dual Rear Leaf Inserts, and Control Arms
Full-Traction Suspension Jeep XJ Cherokee 3.5" Suspension System
Warrior 3" Suspension Kit
Includes: Shocks, Shackles, Coils, AAL, Sway Bar Link, Tie Rod Bracket, and LCA
WAR30930 - 3in Suspension Lift Kit For 1984-01 Jeep Cherokee XJ | Discount Jeep Parts
Rock Krawler 3" Suspension Kit
Includes: Coils, AAL, Adj Front Trac Bar, Trac Bar Relocation Bracket, Drop Pitman Arm, Sway Bar Discos, and U Bolts
: Tellico 4x4
Black Diamond 3" Suspension Kit w/ AAL
Includes: Coils, Shocks, Full AAL's, and LCA's
Black Diamond 3" Jeep Cherokee XJ Lift Kit
4-4.5 Inch Lift Options
RE6130 XJ 4.5" SuperFlex kit w/leafs
Tire Clearance: 32x11.5
Includes: Coils, Full Spring Pack, Bumpstops, Front Track Bar, LCA, Rear Break lines, and RE Gen2 Disconnects
JeepinOutfitters - Rubicon Express XJ 4.5" SuperFlex kit w/leafs, RE6130
RE6111 XJ 4.5" SuperFlex kit w/AAL
Includes: Coils, AAL, Bumpstops, Front Track Bar, LCA, and Break Lines
JeepinOutfitters
Superlift 4" RockRunner lift kit, Jeep XJ Cherokee
Includes: Coils, Full Spring Pack, Shocks, Upper and Lower axle links, Front Track Bar, and Quick Disconnects
JeepinOutfitters - Superlift 4" RockRunner lift kit, Jeep XJ Cherokee, SL-K788
Superlift 4" Standard lift kit, Jeep XJ Cherokee
Includes: Coils, Full Spring Pack, Shocks, Front Track Bar, Upper and Lower axle links, and Quick Disconnects
JeepinOutfitters - Superlift 4" Standard lift kit, Jeep XJ Cherokee, SL-K787
Rustys 4.5" XJ Spring Pack Kit
Includes: Coils, Full Spring Pack, Shocks, LCA, Break Lines, Front Track Bar, TC Drop Kit, and Front Sway bar Extensions
Rustys Offroad:
Rustys 4.5" XJ Add-A-Leaf Kit
Includes: Coils, AAL, Shocks, Rear Shackles, LCA, TC Drop, Brake Lines, and Sway Bar Extensions
Rustys Offroad:
Rough Country 4.5 Suspension Kit w/AAL
Includes: Coils, LCA, TC Drop, Front track bar drop bracket, Swaybar links, Brake lines, Shocks, AAL, and Shackles
Rough Country 4.5 Suspension Kit w/ Full Spring Kit
Includes: Coils, LCA, TC Drop, Front track bar drop bracket, Swaybar links, Brake lines, Shocks, and Full Spring Pack
Fabtech 4 in. Performance Kit
Includes: Coils, Rear AAL, Rear Shackle, Extended Sway Bar Links, and Shocks
Fabtech Complete Suspension System
Rock Krawler 4.5" Short Arm Flex Lift Kit
Includes: Leafs, Coils, Double Adj LCA'a, Sway Bar Discos, and Rear Shims
http://www.jackit.com/manufacturer/rockkrawler/jeep_xj_sa.htm#xj45sa
Rock Krawler 4.5" X Factor Short Arm Kit
Includes: Leafs, Coils, Double Adj LCA'a, Sway Bar Discos, Adj Trac Bar, and Shims
: Tellico 4x4
Rock Krawler 4.5" X Factor Plus Long Arm Kit
Includes: Leafs, Coils, High Adj LCA's, Long Arm Brackets, UTA, Adj Track Bar, Trac Bar Relcoation Bracket, Break Lines, Sway Bar Discos, and Rear U Bolts
: Tellico 4x4
5-5.5 Inch Lift Options
RE6200 XJ 5.5" Extreme Duty lift
Tire Clearance: 33x12.50
Includes: Coils, Full Spring Pack, Track Bar, LCA, Bumpstops, RE Gen2 Disconnects, and Break Lines
JeepinOutfitters - Rubicon Express XJ 5.5" Extreme Duty lift, RE6200
RE6300 5.5" XJLA Extreme Duty
Includes: Coils, Full Spring Pack, Shocks, Track Bar, LCA, Bumpstops, RE Gen2 Disconnects, Break Lines, and Long Arm Conversion
JeepinOutfitters - Rubicon Express 5.5" XJ Long-arm kit w/monotubes, RE6300
T&T Customs XJ 5.5" Y-Link Suspension System
Includes: Coils, Full Spring Pack, Shocks, Track Bar, LCA, Belly Pan, Shock Mounts, Drop Pitman arm, Unibody Bracing System, Shackles, and Sway Bar Disconnects
JeepinOutfitters - T&T Customs XJ 5.5" Y-Link Suspension System, TNT-TT-1112
DPG 5” Suspension System
http://dpgoffroad.com/xjtrailgunner.htm
6-6.5 Inch Lift Options
Rustys 6.5" XJ/MJ Long Travel Suspension Kit
Tire Clearance: 34x12.50
Includes: Coils, Full Spring Packs, Shocks, Trac Bar, JKS Sway Bar Disconnects, and Break Lines
Rustys Offroad:
Rustys 6.5" XJ Spring Pack Kit
Includes: Coils, Full Spring Pack, Trac Bar, UCA, LCA, Break Lines, JKS Sway Bar Disconnects, and Shocks
Rustys Offroad:
Rough Country 6.5” Suspension Kit
Includes: Coils, Full Spring Pack, UCA, LCA, TC Drop Kit, Track Bar, Sway Bar Disconnects, Pitman Arm, and Shocks
Jeep XJ 6.5" Suspension Lift
Skyjacker 6 in. Rock Ready Kit
Includes: Coils, Full Spring Pack, Pitman Arm, and Hydro Shocks
http://www.4wheelparts.com/PDT54902.aspx
Full Traction 6" Kit
Includes: Coils, Full Spring Pack, Long Arms, Quick Disconnects, Track Bar, and LCA
Full-Traction Suspension Jeep XJ Cherokee 6.0" XJ Long Arm Suspension System
Rock Krawler 6.5" X Factor Plus Long Arm
: Tellico 4x4
8 Inch Lift Options
Skyjacker 8" Rock Ready Kit
Tire Clearance: 36
Includes: U-bolts, Double Flex lower control arms, Front brake hoses, Rear brake hoses, Dropped pitman arm, New control arm mount brackets and frame, Rear sway bar end links, Rear shackles, Front bumpstop spacers, Rear bumpstop spacers, Flex series upper control arms, Front sway bar links, Front track bar with steering stabilizer, Rear leaf springs, and Dana 30 cradle and brackets
Skyjacker 8" Rock Ready Cherokee XJ Lift Kit (89-99)
Rock Krawler 8" X Factor Plus Long Arm
Tire Clearance: 36
: Tellico 4x4
Rock Krawler Super 8.0" Plus with Rear Coil Over Conversion
Tire Clearance: 36
Includes: Double Adj LCA'a, Long Arm Brackets, UTA, Torque Arm Bracket, Adj Trac Bar, Trac Bar Relocation Bracket, Rear UCA, Rear 4 Link Mounting Cable, Coil Over Mounting Brackets, Break Lines, Rear Shocks, and Front Quick Discos
: Tellico 4x4
Rustys 8" XJ Long Travel Suspension Kit
Tire Clearance: 36
Includes: Leafs, Coils, Shackles, Shocks, Drop Pitman Arm, Trac Bar, JKS Discos, and Front ans Rear Break Lines
Rustys Offroad:
1 - 1 of 1 Posts
Status
