I'm just curious as to how much axle wrap is acceptable and how much the pinion should or shouldn't move.
My second question: The more arch in a leaf means more axle wrap or is it the other way around?
My pinion and drive shaft are almost perfectly aligned, with the pinion being a little lower than the driveshaft. I tested it and it moved about an inch up. Is this good or bad? *Note: The angle of the pinion and driveshaft were, as far as I could tell, PERFECTLY straight when under load. Please help me...i'm confused
