new brakes?the new XJ has that, is that a good or bad thing? it stops about the same as the green one, but it barelly goes down (the pedal)
If it has a certain ABS on it and it has had brake fluid forced back into the master cylinder during a brake change, this will cause your problem. It happened to me several years ago when ABS first came out. I put pads on the front of a customers truck and forced the pistons into the calipers with a c-clamp forcing brake fluid into the master cylinder. This messes with a valve in the M.C. You'll need to bleed the system real good to get the valve to center back up. Hope this helps. I used to operate my own auto repair for about 20 years.the new XJ has that, is that a good or bad thing? it stops about the same as the green one, but it barelly goes down (the pedal)
