I was changing out the valve cover gasket on my 1996 Cherokee, and was moving the cables and bracket out of the way. Throttle cable uses a ball and socket, cruise control uses a slip on clip, and the kickdown cable uses the same kind of clip.
Not sure what I did, but the kickdown clip broke off at the place where it attaches with the other cables to the throttle lever.
I just got new tires... Is there a quick and dependable way to fix this?
Thank you,
-William
Thank you,
-William
