FYI, I have already replaced the wheel hub unit bearings and removed the driveshaft. The vibration is still there past 55 mph.
I was hoping it would. Unfortunately, it did not. I had a couple units hanging out. They say that they should get up to 75k. They're only lasting 30-35. Timkin if anyone is wondering.You might find that when you fix that unit bearing all your problems go away.
Yup. That is the essence of the whole shebang. I've been looking for the right 76-77 or 81-83 Cherokee now for about a year. A sweet one just popped up in PA, but unfortunately way to far away for me to grab.What do you expect from a dead dinosaur anyway
Gluck, thanks doc!1. pull the tires and check the ring gear for out of round.
2. check your back lash at 4 different points on the ring gear.
3. check the carrier bearing bolt torque.
4 check pinion preload. this will be a little tuff because al the guts are in there. Sometimes just rotating the pinion flange and feeling for unusual drag can give you some idea if the bearing are too tight.
