1 - 7 of 7 Posts
Web Wheeler
Hey real quick, there is a detroit locker with 4.10 gears for sale but they are for 29 spline axle. Can I just use these gears and then pull axle shafts from a 29 spline chrysler axle and have it work in my 27 spline chrysler axle and have it all work?
I want to say definitely, but I would double check the carrier bearing diameter just to be on the safe side. But I'm about 95% sure that it's an affirmative there good buddy...Actually, make it 98%, +/-1.5%
Web Wheeler
Ok cool, that's what I thought. Thanks guys :cheers:
you may need to find a 29 spline drivshaft and change the slip yoke on yours so it will match the 29 spline on the rearend side. I had to do this one time when I switched from 27 to 29...
not a big deal but if you do it make sure you get the drive shaft balanced...
I believe he has the axles and the carrier, so his current R&P set up will be a direct change over just as long as he shims it right.
1 - 7 of 7 Posts
