Well, first things first. What vehicle? What engine? what transmission? and what year?
Now that's out of the way, several things can cause a no start no crank. The first and easiest, is putting the shifter in "neutral" assuming it's an automatic, and trying to start. if no luck and you have a helper, have them, with the shifter in park, hold the key in the start position and smack the starter with a hammer. if it starts, YAY!! if not, then a deeper investigation must be conducted.
The first click you hear when you turn the key to start is the fuel pump priming, which shoud only last a couple seconds. multiple clicking from the solenoid can be a weak battery.
