1 - 10 of 10 Posts
What is the best way to get all the air out of the cooling system.I was pulling the radiator hose off of the goose neck and filling it threw the hose .But now sense it is getting a little cooler the heater isn't blowing hot air.
just empty the system......then fill it..until is "full"...then run the truck...with the cap off....and its gona go down..then fill and fill until you cant no more .....:rofl:
Jabo the above suggestions work great if you have converted to an open system but if you still have the football on the passenger side firewall then you have the closed system and the best method is to park it with the rear higher than the front. Use ramps if you don't have a hill. remove the temp sensor on the rear of the head on the drivers side and fill the system slowly. That sensor hole is now the high spot and the air will eventually start flowing from it. you now have a system that is full and you can re-install the sensor and hook the wire back up.
:) Im not known for my description abilities. Thats just what I do and havent had a problem yet.
Great point, since you have an open system you need to use the above method.
Discussion Starter · #10 ·
Right now I have the closed loop system .But I have the radiator out of a 96 that is a closed loop system and im thinking about installing in my jeep is this a good or bad idea.
1 - 10 of 10 Posts
