1 - 9 of 9 Posts
Trying to figure out if im able to run R/E long arms on this swap kit anyone out there have a pic of someone running this truss with R/e arm?
Your putting an Artec truss on a Dana 60 and want to know if a RE long arm kit will work? Is that what you are asking?
Yes so right now i don't have the 4 link was going to get before this build im running a rubicon long arm, radius arm not sure if ill be able to use them untill i can 4 link it.
If these arms will work i might just keep that set up not sure yet.
The answer is yes if you get the Daystar Bushings in the factory location
See thats what i was hoping for I was worried after reading the artec install instruction it states that hey have only tested with 4 link. Also it moves the upper control arm end up 3 inches which i guess as long as the uppers adjust that far out i should be fine ill post a pic this weekend of progress thank you so much .
I am sure that the three vs four link is a liability thing. I run a three link and it flexes very well. The trick is just like with a track bar. Make the mounting points like a parallelogram.
Yes. those should work
1 - 9 of 9 Posts
