All of my dash lights are working except the heater lights. I don't like having to turn on the interior lights so that I can adjust the heat. Does it has it's own fuse? Where should I start? :brickwall:
Probably the light bulbs. It may be easier to pull one from the boneyard and replace it rather than try to pluck the old bulbs and put new in..
On my 91 there is a fuse that if blow the dash lights plus a couple other things do not work. I forget what all is affected but it's worth looking at all the fuses inside the cabin just in case. if not could be a short or burned out bulbs.
