Whats the deal with the SYE do you have to have this?
Oh, OK, so 94 is the year they started using the TJ D30 on the front end. I was wondering what the year was for that, thanks!!If it is an early vintage XJ you may squeak by with a transfercase drop but as Kyle said every Jeep is different. If it is a 94 or newer it is almost guaranteed that a SYE is going to be required.
As the others stated it depends on your XJ. I have an 87 with around 6.5" lift in the front and 5.5" in the rear and I have a T-case drop kit on mine and it does a great job. I had my driveline lengthened by .5"...and beefed up as well, but that was for another reason!!Whats the deal with the SYE do you have to have this?
No, they didn't start using the low pinion D30 in the XJ until 2000. 2000 and 2001 were the only years the XJ got that axle. And it actually wasn't identical to the TJ axle -- the XJ axle used different LCA brackets.Oh, OK, so 94 is the year they started using the TJ D30 on the front end. I was wondering what the year was for that, thanks!!
I can tell you unless someone came out with one in the last 6 months Hack n Taps are all there are for 242s.Jason do you happen to sell or have info on whether or not those heavy duty SYE kits are available for the NP242? I know that RE makes a hack-n-tap setup...
I was afraid of that..geesh what a pain..Can the hack-n-tap be done with the tcase on the jeep or must it be removed? I guess atleast the hack n tap is fairly cheap..I can tell you unless someone came out with one in the last 6 months Hack n Taps are all there are for 242s.
Cool I assume an electric angle grinder with proper cutoff wheel should work? then it's makeing sure you tap the hole dead center which err seems a bit tough to do..Will have to borrow my neighbors hammer drill..sure would be easier to chop and tap with shaft out..lolIt is best to do the hacking with the engine running and the tranny in reverse and a cutoff wheel on the air tool. after removing the driveshafts. E brake on. Took about 2-3 minutes to shorten the shaft. No real need to remove the t/c and the reverse method gives an even smooth cut.
May be easier to tap with the shaft out but chopping it is easier with the shaft under the vehicle if you use blues method. It works very well.Cool I assume an electric angle grinder with proper cutoff wheel should work? then it's makeing sure you tap the hole dead center which err seems a bit tough to do..Will have to borrow my neighbors hammer drill..sure would be easier to chop and tap with shaft out..lol
Originaly 8.5", but it settled to 8" in the front and 6 3/4" in the rearHow high are you Lilred???
