1 - 2 of 2 Posts
engine / carburetor help
:dunno: I just got a 85 2.5L pioneer, w/no info from previous owner. It has a Vin code ijcub782xft...... the engine build code is 41OU23 the engine looks original but the carb has been swapped to a 1bbl Rochester from a 77 chev 4 or 6. It is a hard start cold or hot. there are un-connected / missing vac lines, wires, breather hoses and the carb air cleaner mount has broken from the air cleaner being to high and the hood slamming down.
Questions: Is this an original AMC 2.5L? Should I put on a Stock Carter FYA? Is a weber 32/36 progressive carb a good choice for replacement?
thanks, jmczzz
it's probably the 2.5/hurricane. i know where there used to be a stocker carb but no way you're gonna get the air cleaner...it's mounted on my wall :D
1 - 2 of 2 Posts
