21 - 40 of 47 Posts
1993 XJ
Discussion Starter · #21 ·
is there a way to pull the inner steering box brace from inside the "frame rail" or is it welded in?
It is welded in
Reactions: warrpath4x4
1993 XJ
Discussion Starter · #24 ·
I picked up a portable band saw and cut off the front frame flanges, cut out some 3/16" plate, bent the sides and dimpled some 3" holes in it.
its not in its final location, just sitting there, I wrapped it around each side 3 inches, I will weld it, and will also add some L-braces on the inside of the rails, along with a piece over the top. First thought the wind needs to quit so I can weld all the cracks up in the frame rails. Thinking I might run another piece off the bottom under the steering box as a skid.
1993 XJ
Discussion Starter · #25 ·
Yesterday would have been a wonderful day to weld outside... if I had gas for the welder.
So being at a stand still on the front I moved to the back, pulled the rear bumper and hitch, while I was under there I noticed this
so now I get to replace the fuel tank, luckily one of the wrecking yards near me has a couple for $57
Then I pulled the carpet out of the rear and started a cut and fold on the rear quarters but I think I got lost somewhere lol
I have done the cut and fold on other Cherokees but this time I decided to just cut it all off with the thoughts of lengthening the rear wheel wells, then I will just plate in what's left.
Hmmm, lengthening the rear wheel wells? Do I see larger tires in the future?
1993 XJ
Discussion Starter · #27 ·
I already have a set of brand new 33's for it I just haven't bothered switching yet. I probably should have gone with 35's but I bought them before I got the 4.88 gears.
1993 XJ
Discussion Starter · #28 ·
I am looking for a set of F150 leaf springs to replace the messed up pack thats in there, that will move the rear axle back 2 inches.
Will that new gas tank still fit?
1993 XJ
Discussion Starter · #30 ·
The tank will be moved up, I am going to cut a hole in the floor and mount the tank half in the cab and half under, I had planned on doing this even before seeing the smashed tank, then build a cover over the tank. I will have to relocate the filler neck but have not decided what to do yet. I am half way thinking about chopping the top off the Cherokee (of course it will be caged).
What some do with that tank is put plexiglas in the rear window and fab a filler neck etc in it
1993 XJ
Discussion Starter · #32 ·
I thought about doing that with sheet metal, wouldn't have to worry about breaking the glass off-road, we have a lot of narrow trails with trees around here.
That would work too
1993 XJ
Discussion Starter · #34 ·
Saturday I worked on the XJ a bit, was able to do some welding before the wind started to pick up in the afternoon. welded up all the cracks i could find (and it was a lot), right now the cross member is only tack welded in place but already adds more stability, without the cross member I was able to push the front back and forth.
The center line is dimple died (my kid loves running the shop press lol) the 2 offset holes are for the radiator lower mounts.
1993 XJ
Discussion Starter · #35 ·
Saturday I put a new water pump, coolant pipe, thermostat, and thermostat housing on
I also removed the heater valve and replaced it with heater hoses from a 2006 TJ
Than pulled the front axle so I can get it into the shop and rebuild it (sleeve the tubes, gears, locker, ball joints, hubs, DOM/Heim joint steering )
when I unbolted the steering from the pitman arm, I have never had this happen before.... the tie rod end just fell out of the pitman arm, I have always had to beat on it or use a pickle fork lol.
1993 XJ
Discussion Starter · #36 ·
I'm not going to post a step by step of rebuilding an axle, I'm sure most of us have seen that before. But... here was my issue yesterday an getting the ball joints out, 3 of them were not that hard, add some pressure from the ball joint press, tap the axle C with a hammer a couple times and the ball joint pops loose and can be ratcheted out. This one on the other hand, I couldn't get enough pressure on it because the leverage of the breaker bar just kept trying to knock the jack stands over so I used a small chain hoist to leverage against the other side of the housing, added a little pressure, couple hits of the hammer and popped right out.
could I have used an impact on it... sure, but I don't like to use impacts on press tools like this, it usually just ends up messing the tool up and this is my tool not a rental lol.
and yes I know its a mess, I have 20 pounds of shop sh!t in a 5 pound bag.
Now that's using your dip stick...lol... your garage is immaculate compared to mine...I'm not even kidding:(
1993 XJ
Discussion Starter · #38 ·
I really need a bigger shop, I have stuff crammed on shelves and in boxes but at least its a cement floor and a roof over over stuff. its actually a 1925 carriage house. cant get the jeep in but I can get an axle in and walk around it without tripping on too many things lol
1993 XJ
Discussion Starter · #39 ·
Have not done anything on this in a few weeks, had to order some bearings, brakes, and u-joints. Had a death in the family and funeral Friday, also Rodeo's for my son the last 2 weekends. All the parts are in now and nothing planned for this weekend so hopefully I can get something done.
HELL YEA!!! How's the boy doin with it?
21 - 40 of 47 Posts
