1 - 20 of 62 Posts
Ok I converted my jeep from 2wd to 4wd and I toke it for a test drive today. Shift great and im very pleased with the way it turned out but I have a vibration coming from the front. I changed out the u-joints with performance u-joints. What else could it be.
Hmmm. I can double check that.
mine happens about 20 mph
something must be loose,, check every joint and every bolt.. IDK man,, im new to 4x4s.. but its a vibes in general are not that good..
Discussion Starter · #7 ·
Im new to 4x4's too. I dont know whats going on. I might remove the front drive shaft and see if its still there.
Discussion Starter · #9 ·
Its not a big deal right now cause im not going to fix it till this weekend when I install my SYE
well why dont you install your SYE first then take it for a spin again to see if you still have vibes..
Discussion Starter · #11 ·
The SYE is only for the rear drive shaft. Isnt it?
I guess, but the front is lower no too so they might have the same problem as the back.. IDK..you have 6.5" lift,,, thats a lot.. for a stock shaft,, check the angles... they might be stressing..
Discussion Starter · #13 ·
i will have to see.
There area number of issues that can cause vibrations in the front end. First suspicion is wheel balance. Get them checked and possibly rebalanced. Also loose or worn ball-joints, a worn tie-rod end, pooched control arm bushings and so forth. Also get a good alignment done on it. Toe could be off a bit, and if the control arms were not mounted exactly factory spec, you may never get rid of the front end quirks.
You mentioned that you converted to 4wd from a 2wd? Did the donor diff get rebuilt as in unit bearings, brake rotors, pads etc? Sounds like you may have some worn out front axle components or something loose.
Any time I have worked on my own front suspension I go back after 30-40 miles or so and re-torque everything, and then again about 100 miles after that just to be sure.
Hope that helps.
Hope that helps.
I install the front axle first and drove it for 2 weeks with no problems. All the bushings, tie rod ends, ball joints, u-joints. I did notice that when I was installing the front drive shaft It wouldnt fit and I had to lower the vehicle to bolt it in.
Did you get a shaft that was for a stick and you have an auto? The auto is an inch or so longer.
I got a front shaft once that threw the weight and vibed like a bitch. I got another one in there and it was mint.
What's your pinion angle like on the front axle? If i'm correct, you are 6.5" on short arms. That could be a pinion angle problem. Try driving without the front shaft. Then try without the rear shaft.
if its a pinion angle how hard is that to fix
Discussion Starter · #20 ·
1 - 20 of 62 Posts
