I am looking to install a hidden fuel cut-off switch as an extra anti theft device. I've read how to's from other forums on how to wire it up, but nothing specific for my 96' XJ. I assume what I need is the fuel pump wire, where would the easiest access point to this wire be?
I would probably put a switch in the ignition on wire rather than just the fuel pump wire, thus killing the whole truck, not just the fuel pump.
muddin moderator
i put my kill switch on the starter and then hid that in a fenderwell this way i flip it off and it looks like im checking my tire
cad, for the kill switch on your starter did you splice the line right at the starter or somewhere around the fuse panel or under the dash?
muddin moderator
i spliced by the starter and ran wire to the fender well
as for suseptable to damage .... kind of but only if i sling gravel up into it
