1 - 20 of 34 Posts
1999 Jeep cherokee xj, I seen the fuel filters are part of the fuel pump assembly innthe tank, my question is can I add a hose clamp style filter externally? Being as though it's a high pressure system.
Welcome to the forum
Yes you can
Preciate it, i replaced one injector (all the store had in stock) now it cranks without the aid of starter fluid but whenever i get down on it bogs and tries to die, thats what got me to thinking filter
How long since your O2 sensors have been replaced
Also you might have a clogged catalytic converter
Cats cut out i recently bought it, it was a play toy for the previous owner, really couldnt tell you on the O2 sensor but if that could cause it i will replace that also
Probably never changed and making you run lean
Ill pull the O2 tomorrow and check on it, thank you for the help I'll let you know what happens
O2 sensor was cut??
Discussion Starter #11
The wires to the O2 sensor is cut off its just a mud toy so I guess the previous owner cut them ill send video
Did you get a check engine light? No wonder it wasn't running right. Get a new one and wire it up. Then take your battery cables off, touch them together, install them and then start it and let the ECM learn all over again. These Jeep ECMs are kind of stupid, so it takes a little while
Discussion Starter #13
No check engine light but Im not sure if that works on the dash the rpm mph and thermostat work but not fuel guage so thats a toss up but ill grab one today and get back to you
OK, if you get it installed I am sure it will run better. Are you getting black smoke out the tail pipe now? That would not be surprising with no data from the sensor
Good opportunity to teach them about cars while you are at it, if they are old enough
Reactions: Arconger
Discussion Starter #17
Replaced 02 sensor and it runs better but spitting and sputtering is still there gonna clean the iac in a little bit
Did you do the battery trick?
1 - 20 of 34 Posts
